Results 1 to 15 of 15
Thread: Need help locating my water supply shutoff for pool
    May 2015
    Austin, TX
    118
    I have looked all around the pool, cannot locate it. I saw something but that is the shutoff for sprinklers. Is the green knob on the bottom left in the picture the pool shutoff. The box is the pool heater
    15K gal, IG (I think its Vinyl not sure), 2 HP WhisperFlo pump, 60 sqft Pentair DE filter, SWG Hayward Aqua rite controller with t-cell-15, Aqualink RS6, Jandy Spa side 4-button, Polaris 280, 400K Pentair Minimax NT Heater Propane, test kit TF100
    Jul 2015
    Central Valley CA
    1,109
    Re: Need help locating my water supply shutoff for pool
    The green device is your gas supply to the heater. By water supply shut off are you referring to an auto fill? they are usually connected to the nearest hose bib. More pictures or a youtube video may help
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    May 2015
    Austin, TX
    118
    May 2015
    Austin, TX
    118
    Heres a video. I dont see any hose bib close by. I see a tap for the garden hose.
    May 2015
    Austin, TX
    118
    Quote Originally Posted by atttech-2 View Post
    Yes i am refering to the auto fill. See video
    Jul 2015
    Central Valley CA
    1,109
    I did not see the shut off in the video it's usually tied to the nearest water line not necessarily at the equipment pad. Since all you want to do is temporarily shut it off in the hopes of some free rain water I would use some string or tape to hold the float up that will shut it off for now.
    There is probably an adjustment screw in the auto fill that could also shut it off but if you use that you will have to recalibrate it when you go back to normal operation
    May 2015
    Austin, TX
    118
    Due to heavy rains in austin past 3 days, the pool was overflowing. The coping and deck around my pool is disintegrating due to the salt water pool. To prevent that i am trying to keep the water level low. I turned multiport valve to waste and let out some water this morning, but i forgot to turn it back to filter position. Later in the day, my controller program kicked in and turned on the pump, water came out of the pool . Luckily i noticed that and stopped the pump, but i lost about 12 inches of water. Now i want to prevent it being topped up using the auto fill, i want to leave it like that and let more rains during the next two weeks top it up. But i cannot locate the shut off. I am going to try and put a wooden block to hold the float of the fill valve up, as a workaround
    May 2015
    Austin, TX
    118
    My autofill does not have a screw, to adjust. Its the old style fluidmaster fill valve, the water height is adjusted by moving the metal clip up and down. Dont know how to shut it off
    May 2015
    Austin, TX
    118
    I think i located the shutoff for the auto fill, its underneath the wooden deck, i will have to crawl underneath to reach it and turn off. Scared to crawl under deck at night, due to snakes and scorpions. I will try it in the morning. For now i have used my kids lego blocks to hold the float raised up
    May 2015
    Austin, TX
    118
    I really need to find a better way to maintain constant water level in the pool. The auto fill is only for top off when level drops. Is there a device i can install to lower water level automatically, in case i am out of town
    Jul 2015
    Central Valley CA
    1,109
    Not that I am aware of specifically designed for a pool. Many that have that type of concern buy a submersible sump pump with an adjustable float valve and put it on the steps. Cost around $50 to $150 depending on model and where you buy. Harbor Freight is usually cheapest if there is one near you.
    May 2015
    Austin, TX
    118
    U mean install the float valve on the steps that are in the pool ? Okay, can u send me a picture of how it looks installed. I have a harbor frieght near my house
    Jul 2015
    Central Valley CA
    1,109
    I don't have a picture of one installed but this is a picture of the style of switch that will work. It can be attached to a Vertical pipe such as some PVC and adjusted to any level or depth of water. It then plugs into virtually any pump and controls the power to the pump
    Apr 2013
    Sacramento, CA
    2,769
    Depending on your pump what attech described above might work.
    I have my doubts that you have the technical know how to install it. It requires knowledge of electrical wiring and how your pump is controlled and wired. Moreover those switches are not listed for use in a pool so their use violates the National Electrical Code. NEC 680.4.
    Do you have an overflow installed on your pool so if it gets to full it overflows into the sewer?
    May 2015
    Austin, TX
    118
    Quote Originally Posted by gwegan View Post
    No i dont think there is an overflow installed . When it rains heavy, i notice the pool water overflows onto the deck
