Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: What is the best material to put around an above ground pool
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    We moved in this home 3 years ago, and I did not think we would have lived here that long. We have a 22 foot Intex pool and last year I put a load of red wood mulch around the pool.
    It seems like for whatever reason over the course of the last 2 years the area in front of the pool and to the right of it has shown in the pictures is very flood-prone. Maybe we just have more rain then I noticed in the first year.
    When I know I have found a lot of mulch in the yard and I think some of it has even washed all the way out to the street and probably in the storm drains.
    Everybody seems to have P gravel around their pool if not mulch. I'm not too good in the yard other than Mowing and trimming the weeds, what is the best material to put around a pool that would actually stay there?
    Intex 22' x 52" - Intex Krystal Clear Sand Filter Pump - flow rate: 2,150 gal per hour
    TFTest Kits TF-100
    Waiting to stop relocating until I build my dream pool!
    Aug 2016
    Wilmington/NC
    115
    Re: What is the best material to put around an above ground pool
    I've been think about what I'm going to put around my pool as well. I did box around my pool area with 2x4's. I call it my weed eater boards because like you I don't want to weed eat near the pool and I wanted something to hold the media that I choose in place (I've been thinking about river stones). I'm still in the process of killing all the left over grass inside my box. I'm interested in see what some people suggest.
    Little ole baby pool. 14' x 42" Pro Series 3300G pool. AG Vinyl with metal frame. Currently installed are a Intex pump/sand filter SF60110 3000GPH and Intex SWG ECO8110. Filled with city water. TF100 Test kit.
    wjr75's Avatar
    Jun 2013
    IL
    836
    I used small red lava rock around the pool I built at my parents house pool 30 years ago that is still there and still looks good. And also those Doughboy pools last!
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,550
    I used river pebbles over landscaping fabric, 14 bags at $3.50/bag. I had previously tried mulch, but it ended up all over the yard.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Thanks! I think river pebbles it is! Why do we do this anyway, what's wrong just letting grass Grow up to the pool, just looks unsightly?
    TFTest Kits TF-100
    Holydoc's Avatar
    Jul 2016
    Navarre/FL
    258
    I put rocks around the outside of my pool because I did not want to "weed-eat" near the pool, and I did not want to chance weeds (or anything else) growing up through the liner. I spray my rocks with roundup ever so often to ensure that I do not have any growth near the pool. If I want some decorative plants, I will place a potted one near the pool.
    19328 Gallon Above-Ground Pool. Clean&Clear Pentair Cartridge Filter. Opti-flo 2 Stage 1.5hp Pump. Dolphin Nautilus Plus "Flipper" Robot. Established April 2016. Taylor K-2006. Chlorine Based. 340gallon Marquis Spa. Bromine based. Established 2007.
    May 2012
    Montville NJ
    545
    People joke that my yard looks like a stone yard - I have a number of different kinds of rock in different places.
    I have 3/4" clean (what everyone calls "gravel" in some spots (mainly for drainage in areas you cannot see)
    I have 3/8" grey pea gravel in some areas - like under the swing set.
    I have 3/8" yellow pea gravel around some trees
    I have what is known around here as Eastern Surnise in some areas
    I have 2" egg rock around the pool.
    Pea gravel gets everywhere - it is too small, in my opinion, to put around the pool. It gets knocked out of wherever you put it too easily. It works great under a swing set, because a good layer (I think I have 8") of pea gravel provides a cushioned surface for around swings and play structures.
    Eastern Sunrise is pretty, it is it like volcanic rock - I really have no idea where they source this stuff from. It is unstable to walk on, and the dog hates it (it hurts his paws). It is also a pain to weed in (because it is so sharp)
    Egg rock (or river rock) works great around the pool. It is large enough to stay in place, but it nests well. The rounded edges make it easy to pull any stray weeds that get into it.
    3/4" clean stone is just ugly - but if you are filling in a 2' deep drainage ditch behind a shed, it is the cheapest way to go.
    When buying stone, bulk is SO much cheaper than bags. If you have a need for any sort of quantity of stone, look into bulk delivery. Or, even better, if you can get it yourself, its even cheaper. Just be careful, stone is heavy. I have a small trailer. It could hold, by volume, about 2 yards of material. I will only pick up a 1/2 yard at a time (there is a place around here that will sell in 1/2 yard quantities) because it is so heavy. I picked up a full yard of 3/4" once, and the way that trailer was creaking, I was aftaid I was going to snap the axle on it.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Thanks Dave!
    TFTest Kits TF-100
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Dave, do you have pics?
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    May 2012
    Montville NJ
    545
    Quote Originally Posted by VinDeeLoo View Post
    Of what? My pool, or the various rock? But if you want pictures of pea gravel or eastern sunrise, that will have to be later.
    I have the pool handy
    Zodiac Wahoo
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    And that's the solar cover holder design! Much better than what I was going to do. Thanks for the pic, phonedave!
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    The pool is what I wanted to see. Thanks!
    VinDeeLoo
    May 2012
    Montville NJ
    545
    Quote Originally Posted by RyanMcC View Post
    Thanks. I did not want it hanging on / supported by the rim of the pool. The ground holds all the weight. I drilled the holes into the bottom of the support caps, and the whole thing tips up into them, to keep it from moving around. I didn't glue any of it, because I though I would take it in for the winter. I never did, and this will be its third winter with no problems. No problems with leaving it in place and putting on the winter cover.
    -dave
    Zodiac Wahoo
    Jul 2016
    Noblesville, IN
    30
    Love the design. One question - would there be a problem if I were to raise up the cross members so the cover would be further off the ground when in the holder? Thought is that would make it easier to reach over to grab it from inside the pool.
    Pete and Family
    Graduated from baby wading pool to Quick Set Intex 10 ft to Intex steel frame 12 ft over the last 5+ years
    Just purchased BestWay 22 ft x 52 in on clearance - will graduate to it next spring!
    May 2012
    Montville NJ
    545
    Quote Originally Posted by PurduePete97 View Post
    Sent from my XT1585 using Tapatalk
    I don't see a problem with doing so. With the set up the way I have it, when I pull the solar cover off of my 27' pool, and let it fall loosley into the holder, the top is about a foot below the top edge of the pool. Keep in mind that I have to fold the edges in as I take it off. The cover is 27' wide, and the holder is about 15, so with the whole cover in there, it takes up aboul all of the space.
    -dave
    Zodiac Wahoo
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Here's what I ended up with. River rock at home depot. On the last day of summer of course.
    TFTest Kits TF-100
    Jun 2015
    Carlton/oregon
    6
    I love how the rocks look but I worry about them working their way under the liner. I have an ultra frame intex. Any issues with that?
    Thanks
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    I thought of that. But there are thousands of pounds weight behind that pool wall. I just don't see how it could get under there.
    TFTest Kits TF-100
    Feb 2017
    Richmond, Va
    2
    I cleaned out a 2' area from the pool wall. I placed black metal edging at the outside edge of the 2' space. I then put down a material weed block in the space between the metal edging and the edge of the pool. I then filled with white marble rocks/chips. Looks nice and clean and easy to weed eat around. I spray with roundup when needed.
  20. Back To Top    #20
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Quote Originally Posted by Jasteriny View Post
    Show us your pictures!
    TFTest Kits TF-100
