Results 1 to 10 of 10
Thread: Stripped Air Pressure gauge causing leak
    Aug 2016
    Brooksville
    11
    Hi,
    I just purchased a house with an in ground pool. The pool has a Posi-Clear Filter. The pressure gauge was broken so I bought a new one. Unfortunately, it was cross threaded when they put it in (It is platic threads. I removed it, but when I put the new one in, I have a small water leak. I tried using extra teflon tape and that did not help. I don't want to pull it out again because it will just make it worse. Can I just caulk the leak around the pressure gauge? Do I need to purchase a new top to the filter from Posi-clear?
    It is just a very small trickle of water, but I want to make sure it gets fixed.
    Any help would be greatly appreciated.
    Scott
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Stripped Air Pressure gauge causing leak
    Welcome to TFP! Congrats on the new pool!
    Caulk rarely works. You can try more Teflon tape or try some pipe dope or both. Other options are drill and tap the hole to the next size up and use a bushing.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,230
    +1 try it with a bit of pipe dope (just don't get any on the little hole in the bottom of the gauge stem)
    It's a common problem when mixing metal and plastic threads. The trick is to turn the male side counter-clockwise with slight pressure. When you feel the male thread drop into place, then turn clockwise. If you feel it shift out of straight alignment, stop. Back it out and have another go.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Dec 2014
    Houston, Texas
    134
    Go to your local hardware store and pick-up a (1/4-18NPT) tap. It has a square end that takes a 7/16 end wrench. Make sure it's straight and start threading it into the hole in 1/2 rotations at a time. Every 2 full rotations back it out 1 full rotation and continue to thread it back in. You'll do this till you're 3/4 to 2/3 the way in. That should be good enough to cut new threads for your gauge.
    GL!
    Aug 2016
    Brooksville
    11
    Thanks guys. Do I need to pull it out to put on the pipe dope? I don't want to make it worse and it is already pretty lose.
    I should add... I am not handy!
    DFW, TX
    24,450
    Yes, remove it to add pipe dope to the threads.
    Aug 2016
    Brooksville
    11
    Went to the plumbing shop today. The guy told me not to use Pipe Dope as it is more of a lubricant than a sealant (Same with the tape). He told me to use a thread sealant. He also said that I might not get it off if I need to change it out.
    Since I don't know much about this, what is everyone's thoughts on this?
    Greatly appreciate everyones help so far.
    Scott
    Jul 2015
    Central Valley CA
    1,107
    They are both a lubricant and a sealant I don't know a single plumber what would claim otherwise and I know 3 plumbers. I would not use thread sealant at least not until I first tried the suggestions above. Try the tape alone first, then the tape with dope, then if both those fail tap a size up and use a bushing. One of those will work. If you are uncomfortable doing the work I would bet a landscaper would do it fairly cheap what you need done is not any more complicated than working on an irrigation system
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Aug 2016
    Brooksville
    11
    Quote Originally Posted by atttech-2 View Post
    Thanks for the info. I already tried the tape, and it did not help. Right now, it is not leaking, so I am just going to keep an eye on it. But if necessary, I will try the suggestions above. Everything I have seen indicates that the pool filter by Sta-Rite is a piece of junk. You can't even get a new top for it because it is Obsolete (Even though it is only 10 years old).
    Scott
    DFW, TX
    24,450
    I agree with atttech-2 and my original response. Don't ask that guy for advice again, he knows not! It is fine to leave it be since it isn't leaking. It is also ok to try using more Teflon tape. Sta-rite was purchased by Pentair not too long ago. I don't know if it was good or bad before that. It is good now.
