Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: Pool Temperature
    Jul 2016
    Salina, KS
    52
    Pool Temperature
    I know this is completely up to each person, but what do you find the ideal water temp is for you and your families? Just curious as to what people like.
    Kevin
    IG Tile/Concrete Pool - 12,000 gal or so, Targus Sand Filter, Pentair single speed pump
    IG Tile/Concrete Spa
    Dec 2014
    Santa Ana, CA
    523
    Re: Pool Temperature
    Quote Originally Posted by bigkevj View Post
    82-86
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Jul 2015
    Central Valley CA
    1,106
    I would have said 83 to 85 but essentially the same as max2k
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Ditto, and 101 in the tub. 100 doesn't quite do it, and 102 chases us out too soon.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    ateam's Avatar
    Jul 2015
    San Antonio, TX
    29
    Agreed, if I'm heating my pool in the off season I normally shoot for around 85.
    in-ground pool/spa with spill over, plaster/pebble, multiple waterfalls
    4x Pentair pumps, Pentair DE filter, Pentair Heater, Auto-fill
    Completed 2011, TF-100 test kit w/ Speedstir
    Surf_ox's Avatar
    Aug 2016
    Cypress, TX
    40
    Depends on what I'm doing just prior.
    Mowing in 103 deg temps. It doesn't really matter I'm going in
    We enjoy the mid to lower 80s also
    However a polar plunge is always on the schedule in January.
    Don't ever hesitate to try something new. Remember amateurs built the ARK and professionals built the TITANIC.
    13K; IG Pebble sheen [4,5,4] with sun deck; 2hp pentair cleaning the water through a Clean and Clear Plus; 2hp pentair flowing the natural rock waterfall and 3/4 hp powering the 2011 Pentair legend (AKA "THE DUDE")
    May 2015
    Land O Lakes, FL
    527
    85 to 87
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    May 2015
    Land O Lakes, FL
    527
    Remember that while thermometers should all measure the same, they don't. ☺️☺️
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    True that ^^^^
    Totally depends on the air temp. 8-10ish degrees below ambient is pretty good. 93 and up is always too hot. 80 or less is always too cold.
    Jul 2016
    East TN
    45
    82-86 for me as well.
    18x36 8ft deep end (~27k gallons), IG, Vinyl Lined, Polaris 360 Cleaner
    Sand filter, 2HP Pump, Municipal Water Source TF-100 Test kit
    East TN
    CYA Chart SLaM Add DE to Sand OCLT
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,047
    88-90 is great for us
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    570
    80-82. Its been hot summer. That number will drift up as fall comes.
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    Messman750's Avatar
    Jun 2015
    Groton New York
    34
    78-82 is ideal
    32x16 inground chlorine. 23000 gallon with diving board
    vinyl liner 1hp hayward super pump. Waterway sand filter new in 2014.
    maytronics dolphin m200 robot. I live in central NY.
    TF100 kit Taylor speedstir. Sonos audio
    Holydoc's Avatar
    Jul 2016
    Navarre/FL
    258
    Quote Originally Posted by mgmoore7 View Post
    85 to 87
    This is around our best temperatures too. But like MGMoore, we are also in Florida so anything below 90 degrees is great!
    19328 Gallon Above-Ground Pool. Clean&Clear Pentair Cartridge Filter. Opti-flo 2 Stage 1.5hp Pump. Dolphin Nautilus Plus "Flipper" Robot. Established April 2016. Taylor K-2006. Chlorine Based. 340gallon Marquis Spa. Bromine based. Established 2007.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I would say 84 degrees for the pool, and I find that as I age this number goes up about 1.5 degrees per decade or so, if you would have asked me 6 years ago when I first joined this forum I would have said 82-83, even last year it might have been 83, but now it is leaning towards a solid 84, back in my teens and early 20's I was content with pool water at 77-79 degrees.
    Jun 2015
    Orange County, CA
    144
    85 degrees
    17k IG plaster pool+ spa, Stonescape mini-pebble midnight blue, marble coping, Trex and porcelain tile decking, Pentair Intelliflo VSP x 3 (filter, laminars and spa jets), Pentair IC40, Pentair MasterTemp 400, Pentair Quad DE 100, Pentair CC 150 for laminars, Intellibrite 5G LEDs, MagicStream Laminars x 3, Intellitouch i9+3 automation with Screenlogic2, IntellipH, Dolphin s300i, TFTest kit, SpeedStir
    Jul 2015
    Central Valley CA
    1,106
    Quote Originally Posted by Isaac-1 View Post
    Leave it to a TFP Expert to put a formula to it
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I like my pool at 82-84. Any warmer than that and it doesn't feel... refreshing. Now if it's a 70 degree day in September, 86 would feel great!
    Isolated Spa - 345 Gallons
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    I will swim all the way down to 78 but prefer 83-85.
    Dolphin E10 Cleaning Robot.
  20. Back To Top    #20
    Saturn94's Avatar
    Mar 2015
    Virginia
    496
    86-88
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
