Thread: Dolphin Premiere vs Dolphin Quantum?
    Jun 2014
    KISSIMMEE
    10
    Hi everyone! I'm looking to purchase a robotic pool cleaner but confused on which model is maytronics newest and cleans better? I have a 6,000 gallon pool an saw on amazon premiere and quantum are 2016 models. Can someone tell me which model I should get that cleans better?
    I also spoke to a sales rep at maytronics and they mentioned to me Premiere is the best choice
    6K Gallon Concrete Pool
    May 2011
    Orange, TX
    66
    Re: Dolphin Premiere vs Dolphin Quantum?
    Interested in this as well. Also, found both of these online where the seller claims to be an authorized seller and honors the warranty. Maybe this only applies to the Cayman and Premier and not the comparable 'S' series?? I have emailed Maytronics to see what they say about that online sale.
    20,500 gallon free form, 6X9 hot tub w/ spillover, 18" jumping platform w/ 3ft shear descent on chopped rock, Travertine coping, 2.5HP Hayward 2-speed filter pump, 525 Hayward Cartridge filter, 350K BTU Hayward NG Heater, 2HP Hayward water feature pump, Satin Matrix Northshore Carribbean, Jandy PDS-8 Controls
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,541
    Thrill,
    I have the Premier, and while it works fine for me, it is worlds behind the newer Quantum. The Quantum is similar to all of the new Dolphins.. it has a much bigger basket, allows you to use both the screen filter and pleated filters at the same time, uses water jets to hold it to the wall, instead of a floating arm, has top loading basket, instead of a bottom basket, and ... I suspect there is more, but that is enough for me. The next robot I buy may not be the Quantum, but it will sure be that style of cleaner..
    Quote Originally Posted by Jimrahbe View Post
    Thrill,
    I would have to agree to the major points. Losing the float arm is an evolutionary step. The float arm can get wonky and if there's a less cumbersome way to achieve the same result then that's the way to go. As for the top-loading basket and its ease of cleaning. That should be the industry standard.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
