Results 1 to 9 of 9
Thread: First year owning a pool, what cover for the winter??? please help
    May 2016
    Toronto
    129
    Hey,
    I am located in Toronto and this is my first year owning a pool.
    I took over this house, got the pool up and running (looks great), but will need a winter cover.
    Should I get a winter cover or a safety cover?
    This is the one I'm thinking..
    Covers :: Safety Covers :: Rectangle Stock Safety Covers :: 16 x 36 ft Rectangle Stock Safety Covers :: Solid Safety Covers :: 16 x 36 ft Rectangle Safety Cover Lite Solid
    Any cons to getting this?
    Should I consider something else. Ideally, my budget is under $1000.
    16x34 In-ground vinyl pool (22,000ish gallons), Sand Filter, K-2006 test kit, SWG
    GeorgiaPoolOwner's Avatar
    Jun 2015
    Canton, GA
    63
    Re: First year owning a pool, what cover for the winter??? please help
    Quote Originally Posted by crocop View Post
    Hey,
    What do you want out of your cover? Do you have kids? When do you expect to reopen your pool? It all depends on what you want.
    I have a safety mesh cover. I love it. Critters aren't going to cause it to collapse, and my kids aren't going to fall in. They know not to walk on it, but of course, kids are kids, so they have managed to get on it before. They did not fall in and it was almost like a trampoline (although I got them off within seconds). The cover served it purpose.
    A safety cover has fine holes in it for water to drip through. Because of this, some sunlight will get in. If you are not concerned with anything getting into your pool, a winter cover/tarp with water bags is advocated by some because it does not permit any light in. When the water gets above 60 degrees, if you have light, algae will develop. I opened to a dark green pool in May (see photo), but it only took 2 days of SLAM to clear up.
    We received so much rain last winter, it refilled my pool completely. I could not imagine having a cover that did not permit the water to seep through. It would have sunk.
    Free form pebbletec finish; Hayward pump, cartridge filter; SWCG - Hayward T Cell 15; K-2006C.
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    +1 to what GeorgiaPoolOwner said. I had the same situation on opening in May with a mesh safety cover.
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    wjr75's Avatar
    Jun 2013
    IL
    836
    If you buy that cover you will still need to have the retractable screws installed into your pool deck.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jun 2015
    Fairfield Twp, OH
    216
    wjr75, it says the hardware is included. I guess as long as the OP is willing to do the install themselves, there isn't a problem.
    wjr75's Avatar
    Jun 2013
    IL
    836
    Yes, the springs are included but you need to drill holes into your pool deck that has a screw that comes up that it attaches too. I'm not an expert on the installation but I wouldn't do it on my own. But that's just me.
    May 2016
    Toronto
    129
    Thanks guys.
    Is drilling the holes a DIY job? I assume it is..The safety cover I posted says it protects 100% of sunlight, is that not true?
    If I get a winter cover with the water bags, I assume I have to pump of the water and debris every few weeks if it fills no? What if it snows on it?
    Also, will the winter cover with the water bags give me a better chance to open up to a clean pool?
    Quote Originally Posted by GeorgiaPoolOwner View Post
    Thanks for this. Ideally I want to close as late as possible and open as early as possible. I have a gas heater so can make use of it too.
    This is great info though.
    Is a mesh safety cover like I posted more, less of the same work as going the winter cover with bags route?
    May 2016
    Troy IL
    476
    If you have a hammer drill or know where to rent one, I'd go for it as a DIY job if you are at all handy. That's assuming you have a concrete deck. If it's wood, then heck yes do it yourself. Drill the holes as straight as you can and you should be fine. I just installed a pool fence from diypoolfence.com, and that was pretty easy, but if you get the holes in the wrong spot or angle it causes all kinds of problems. With this safety cover,you won't have that issue, you just have to get it in the general area of the strap. Once all the holes are drilled, you can adjust the strap to take out slack.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    Jul 2016
    East TN
    45
    There are several vids on YouTube on how to install these safety covers. If you are handy at all these look like they are fairly simple to install.
    18x36 8ft deep end (~27k gallons), IG, Vinyl Lined, Polaris 360 Cleaner
    Sand filter, 2HP Pump, Municipal Water Source TF-100 Test kit
    East TN
    CYA Chart SLaM Add DE to Sand OCLT
