Thread: After the SLAM question
    Jul 2016
    Whitesboro, TX
    85
    I recently finished my slam passing OCLT, water looks great, and combined chlorine of zero. My CYA is a 70 so my SLAM level for full chlorine was 28. Currently I am waiting on my chlorine to fall to get an accurate PH and TA reading. Am I correct in saying that those won't be accurate until I get my FC below a 10? Right now I am at a reading of 16 FC. I feel like I have read that somewhere but not sure where on here. Thanks so much!
    22' Round x 52" deep Coleman AGP, 12,500 gallons. Filled 5-1-16. XtremePowerUSA 4500 GPH 19" Sand Filter w/1.5 HP Pump. Hayward Dyna-Skim In The Wall Skimmer. Hard Plumbed w/2" PVC. PVC Aerator. Pentair Kreepy Krauly Lil Shark Above Ground Pool Cleaner. Whitesboro, TX (North Texas). Taylor K-2006 Test Kit Comp Chorine FAS-DPD. Use The Pool Math App By Trouble Free Pool For Logging.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: After the SLAM question
    I don't know about the TA but the pH will not be accurate above 10ppm FC.
    Solar Blanket, Well Water, Borax Added. 68
    Jul 2016
    Whitesboro, TX
    85
    Sounds good! Thanks!
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,255
    I would test TA about the 10 ppm threshold and below just for informational purposes only. Now that you have completed the SLAM, please maintain the appropriate FC levels and brush pool often to keep everything moving.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    30,419
    TA test is unaffected by higher FC....test anytime. pH test needs FC to be 10 ppm or below to be accurate.
