Results 1 to 7 of 7
Thread: Pool liner discoloration in deep end
    Aug 2016
    Long Island, New York
    2
    Hello! I recently purchased a home with a pool. After clearing from a DARK green, I'm seeing a discoloration in the pool liner, which exists only in the deep end. I've tried brushing and even swimming down and scrubbing, and it won't come off.
    Is this something that can be fixed? Certain chemicals perhaps? Any help is appreciated! Thank you!
    40,000 gallon, IG vinyl liner pool
    DE filter, Hayward super pump
    Leslie's 6-point test strips (and visit store) to test chemicals
    Pool built in 1980s
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Re: Pool liner discoloration in deep end
    Welcome to TFP!
    Please add your pool info to your signature and provide the requested info here so that we can better help you. Pool School - Read This BEFORE You Post
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Get a PVC coupling or some other kind of plastic ring and a plain old vitamin C tablet. Swim down and place the ring on the bottom and the tablet inside. You can do it without the ring, but it may go sailing away when you swim back to the top. Wait about 15 minutes and see if the liner lightens where the tablet was.
    If it does, you may have metal issues. If it doesn't, it could either be organic staining or mold on the back side of the liner. Organic staining will lighten over time with maintained chlorine levels. Higher levels will lighten it faster. Mold on the outside is a tough issue, and that is what it looks like to me from the picture. I hope not.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Do you have any photos of how it looked before you cleaned it that you can post ??
    What type of material did you get off the bottom when cleaning, leaves, animals, ... ??
    Solar Blanket, Well Water, Borax Added. 76
    Aug 2016
    2
    Here's the pool when I first opened it. I don't think it was opened at all last summer, and it was dark green. It was covered by a Loop Loc, so not too much debris was in the pool - some leaves, a couple twigs, and that's about it.
    Pool built in 1980s
    30,432
    Did you try the vitamin C test yet?
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Did you drain and refill or SLAM it into submission ??
    If you drained and refilled I might try raising the FC to SLAM level for a day or two to see if it helps. But I'd try the vitamin C test first in case it's metal staining. Pool School - Metals in the Water and Metal Stains
