Generic chlorine bleach ok...or just clorox?
lwebb
Jun 8, 2008
7
Getting ready to put the intex up again. Started BBB last year and always bought Clorox, but husband says generic is just the same. True or not? Yes, this would be pinching pennies, but why pay more unless necessary!
Thanks!
The off-brand Regular bleaches are often 3% or less while the off-brand Ultra are typically 6%. The only technical difference between Clorox Regular and the off-brand Ultra bleaches is that Clorox Regular has less "excess lye" in it so will result in a lower pH rise over time. With the off-brand Ultra bleach you may be adding perhaps around a 0.3 unit increase over a cumulative 100 ppm FC, so not that bad. With Clorox Regular, there is effectively no pH rise over time from the bleach itself.
Excellent info! Thanks!
:cheers:
Do not use Clorox Plus HE in swimming pools. You do not want the thickening agent in the pool. If you are using Clorox brand, only use Clorox® Regular-Bleach (grocery stores) or Clorox® Ultra® Germicidal Bleach (commercial cleaning supplies).
