Results 1 to 10 of 10
Thread: Generic chlorine bleach ok...or just clorox?
    Getting ready to put the intex up again. Started BBB last year and always bought Clorox, but husband says generic is just the same. True or not? Yes, this would be pinching pennies, but why pay more unless necessary!
    Thanks!
    Intex Frame Set AG
    12'x36" 2,500 gallons
    cartidge filter
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Generic chlorine bleach ok...or just clorox?
    Generic is fine. Just make sure it's unscented, and check the concentration (5.25% or 6%). Lots of forum users use the Ultra brand from Wallyworld.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Mar 2007
    San Rafael, CA USA
    12,082
    The off-brand Regular bleaches are often 3% or less while the off-brand Ultra are typically 6%. The only technical difference between Clorox Regular and the off-brand Ultra bleaches is that Clorox Regular has less "excess lye" in it so will result in a lower pH rise over time. With the off-brand Ultra bleach you may be adding perhaps around a 0.3 unit increase over a cumulative 100 ppm FC, so not that bad. With Clorox Regular, there is effectively no pH rise over time from the bleach itself.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    12,078
    I use Walmart's store brand, and Target's, and Aldi's. Avoid Dollar Store and bleach from Big Lots.
    Thanks!
    Intex Frame Set AG
    cartidge filter
    Anyone know anything about Clorox Plus HE for high efficiency washers. It is thicker which I would assume means has a thickening agent in it.
    Middle Georgia
    15x48 Intex AGP
    Standard issue pump(1000 GPH)/cartridge filter
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    judging from the msds it looks ok, but I could be totally wrong. I'm surprised at the variation in chlorine availability as opposed to the regular bleach. but don't take my word for it.
    http://www.thecloroxcompany.com/product ... ch7-07.pdf
    It appears to be std issue bleach but thicker from what I see. No percentage on it at all. The MSDS states 5-10% so it's good there anyway
    Middle Georgia
    15x48 Intex AGP
    May 2009
    Dallas, TX
    785
    Quote Originally Posted by chem geek
    Excellent info! Thanks!
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Do not use Clorox Plus HE in swimming pools. You do not want the thickening agent in the pool. If you are using Clorox brand, only use Clorox® Regular-Bleach (grocery stores) or Clorox® Ultra® Germicidal Bleach (commercial cleaning supplies).
