Thread: Overfill
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    353
    Overfill
    Okay, did something that I know NOBODY ever does...turned the hose on to top off a little bit and remembered to turn it off after returning from dinner two hours later....
    Everything is now on the money, except TA is up to 100 (even using softened water) and Borates down 30. Marginal on both ends. Is it better to:
    A: Correct TA before adding Borates
    B: Add Borates and then correct TA
    C: Ignore it for the rest of the season and fix in the spring?
    CYA is also down a little, I'll fix that regardless.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    30,419
    Re: Overfill
    With not much more than a month left, if that. I would pick "C".
    Feb 2009
    353
    Re: Overfill
    Thanks, Dave. That's what I was thinking too. I'll cover it when I close it and worry about it when I test upon re-opening.
