Thread: Will this lower my chlorine levels?
    Jul 2011
    Galloway, NJ
    23
    The crappy pump went on our Summer Waves pool. Of course it was while we were away. Finally got a sand filter/pump set up the other day and had a green pool. Listened to a pool store guy's suggestion (I know, I know) of adding a certain amount of "shock." The green went away literally overnight.
    But now I'm still way over-chlorinated. My TF100 should be here on Friday or Monday. I just got the water tested at my hardware store and here are my numbers.
    FC: over 15.9 ppm
    TC: over 15.9 ppm
    Combined Chlorine: 0.0 ppm
    pH: 7.3
    Hardness: 15 ppm
    Alkalinity with stabilizer correction: 50 ppm
    CYA: 4ppm
    No copper or iron
    The hardware store employee gave me 2 bags of what she said would lower the chlorine. I just got home and looked at the bags (had a 2 year old tugging on me in the store, so I just grabbed them and left). It says pH-Acid Powder. Safely and effectively lowers pH. Active ingredient: sodium bisulfate 100%.
    Is this the right thing? I don't want to add it and screw up the pH that seems to be OK by these numbers. But my pool barely gets any sun because we live in the woods, so this heat hasn't been helping the chlorine drop very quickly. It's been 2 days of being non-green and over-chlorinated.
    18'X48" Summer Waves 7600 gallons
    1 HP Hayward sand filter/pump combo
    TF100 test kit
    Still have so much learning to do
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Will this lower my chlorine levels?
    That's dry acid and will lower your pH. Don't add anything right now, your chlorine will fall on it's own. Post your numbers when your test kit comes.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    30,403
    After you get your money back for the sodium bisulphate, run as fast as you can from that store.
    Learn to manage your pool by yourself and your good test kit.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    More about pool chems here, Pool School - Recommended Pool Chemicals
