Thread: Pool store products?
    Aug 2016
    Coamo,Puerto Rico
    14
    Hi
    before I discover this site y bought some products to clean my pool, the one that I haven't install yet because I still making my small patio, so my question is should I use them for this time or throw away $80 in products. If I use this product just this time how bad it will be?
    18x48 Summer Escape above the ground pool
    SF 70119 intex sand filter and pump
    6450 approx gal water
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pool store products?
    The muriatic acid is very useful and is the best way to lower pH. Even though you probably paid more than you would have buying that product at a hardware store, it's very useful.
    The ReFresh is a cal-hypo based shock product. This product will raise your FC and your CH. You can likely use it in your AG pool as long as your CH level is not high in your fill water or in your pool already. Prolonged used of cal-hypo products can lead to calcium scaling at the water line.
    Clarifiers are not needed. Very rarely they can help to clear a pool that has poor filtration and needs help coagulating suspended materials in order to filter them out at the end of a SLAM procedure. Certainly not an item that I would use. Return that one if you can.
    Isolated Spa - 345 Gallons
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    What he said.
    Solar Blanket, Well Water, Borax Added. 68
    Aug 2016
    Coamo,Puerto Rico
    14
    Thank you for the advice, definitely won't be buying the products on a pool store again. Unfortunately I can't returned because I don't have de receipt because y throw it away because I not thinking I won't be using it. But I learn my lesson.
