Results 1 to 9 of 9
Thread: New liner with gravel underneath
    Aug 2016
    Cullman, al
    3
    We are having a new liner installed and noticed there is alot of that pea gravel underneath it. It has not been trimmed out yet they have just added a small amount of water. Should we have them pull it up and remove that or will it make a difference?
    30,426
    Re: New liner with gravel underneath
    Welcome to the forum.
    I assume you are talking about an AG pool right?
    Aug 2016
    Cullman, al
    3
    Shekkie's Avatar
    Jul 2015
    Grafton, Ohio
    68
    I'd find that to be to be unacceptable.
    33k(ish) gallon, IG, vinyl liner, Pentair IC60 SWG, Pentair Triton II sand filter, 1.5hp Pentair VS pump (SuperFlo), Sta-Rite (Pentair) 400K BTU heater (LP), (2) Pentair LED spa lights, TF-100 test kit w/speed stir
    30,426
    Yeah, that's bad stuff. That will not last or, at best, will be incredibly uncomfortable to walk on.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to TFP Thornton What he said about being uncomfortable and it sure looks like it might tear pretty easily/quickly.
    Is it an in ground pool ?? Google
    Solar Blanket, Well Water, Borax Added. 68
    Aug 2016
    Cullman, al
    3
    Yes, it is an in ground pool. He hasn't cut out the steps or skimmer hole, the liner is just in with a vacuum running and some water added. Do you think it would be a hassel to remove the liner and clean that up and then lay it back in? He said he had it all clean and that some pea gravel must of gotten dragged down on the floor when they were laying in the liner.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    IMHO it's too rough. He may have had it all clean and smooth (the way it should be) but now it isn't.
    Now would be the time to fix it. How easy do you think it would be to get that guy back in a year if it tears and it's leaking and then how much trouble to fully drain and pull the liner ??
    wjr75's Avatar
    Jun 2013
    IL
    836
    I vote for fix it. That would drive me nuts.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
