Thread: Intex U supports buckled and I need ideas how to replace
    Aug 2016
    Baytown/Texas
    4
    Hi all, I just had a bad storm which caused the ground to shift and the 12x12 paving stone to crack which caused my Intex U Support to buckle. I am looking for possible replacement ideas so I can avoid having this happen again. Thank you all
    I Have an Intex 9x18x52 Ultra Frame pool with an Intex 14 inch sand filter, a Hayward 1hp pump and a Intex Crystal Clear Salt Water system.
    Jun 2016
    The Netherlands
    5
    Re: Intex U supports buckled and I need ideas how to replace
    1. Order a new leg
    2. Empty the pool
    3. Fix it and fill it again
    I'm afraid that's the only way.
    Good luck!
    In this link you can see what happened to my legs when I filled the pool for the first time. This is a Belgian forum in Dutch language so I don't think you can read it but you can see the pics. Breaking of the legs was due to a small brick that didn't give enough support. The forces are tremendous!
    http://zwembadforum.be/onderwerp/pech-bij-opbouw-intex-ultra-frame/
    Oct 2007
    Cedar Hill, TN
    251
    I looked at the pictures,
    seemed like the brick was placed the wrong way. Only 1/3 of the leg was on the brick, the rest was hanging in the air.
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    Aug 2016
    Baytown/Texas
    4
    I saw a post from a person that had the same problem and they designed their own leg supports out of emt conduit. I would really like to reach out to that person and see what dimensions they used. I am new to this and would really like to contact Hairsprayed. Any guidance is appreciated.
    Jun 2015
    Stockholm, Sweden
    250
    Hairsprayed hasn't been active on the forum since May 2015. Try sending a PM by clicking on his/her name, then selecting Private Message.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Jun 2016
    The Netherlands
    5
    Quote Originally Posted by heikejohn View Post
    Youre absolutely right heikejohn. Didn't know the forces were like that with the result shown. Now I'm using patio tiles. (Is this the right name.) They are ok!
