Pool has turned murky after raining for 3 days straight. Tested FC/CC around noon today then the rest of the numbers a few hours later to make sure there wasn't something off:
FC 3.5
CC 0
CYA 30
TA 110
CH 300
With so much cloud cover and the lower temps FC hasn't seemed to drift lower very much so I don't think it's dipped low enough to let algae bloom, but maybe I'm incorrect. I took the off trippers off the pump timer to let it run 24/7 and I don't see any areas where there could be runoff into the pool for debris to make it cloudy. I took FC up to shock level just to be thorough, but curious if there is something else I should be thinking about other than just running the pump continuously until it clears up?
FC 3.5
CC 0
CYA 30
TA 110
CH 300
