Thread: Help with new pool.....
    Jun 2016
    Indiana
    5
    Well I know pool season is almost over, but after a few complications with the pool company, my pool is finally up. I couldn't get anyone to haultimate water in, so I had to fill with my well. Now I have a 24' x 52" red watered pool swamp. Where do I start? I refuse to buy from local pool store since the fiasco. Where is the best to purchase products? What should I be adding to get this water cleared up for maybe a few weeks of use? Thanks.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,280
    Re: Help with new pool.....
    Welcome to TFP! Good to have you here
    Start by clicking the link below in my signature "Read Before Posting", and following the instructions there. This will help you get the best possible advice.
    Next, read: Pool School - ABCs of Pool Water Chemistry
    And: TFPC for Beginners (first two posts in that thread)
    If you want to save time, order this right away: TFTestkits.net
    Keep pump and filter running 24/7 to start cleaning the water. Sounds like you have iron as well, so do some searching in Pool School to learn more about it.
    As soon as you get the sense of it all, you need some stabilizer and liquid chlorine in the pool, as soon as possible. You can get it at Walmart. Learn PoolMath (linked at the top of every page) to determine the quantities.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    More here on pool chems, Pool School - Recommended Pool Chemicals
    I buy bleach at the grocery store, store brand. And CYA/stabilizer and muriatic acid at Lowes.
