Results 1 to 8 of 8
Thread: Webfeet's Pool Pictures
    Just wanted to post a link to pictures of our pool. We will be putting a waterfall in directly across from the cozy cove spa. We built the fence and the pool shack. We also designed and did all the landscaping. However, we had a landscaper lay the centipede sod and install an irrigation system. We plan to build cafe type doors for the pool shack. The shack houses the equipment and a changing/restroom. I know its rustic, but sort of tiki like. We love it.
    20 x 40 Grecian inground liner pool
    Richardson, TX
    I think it looks great! I love the 'rustic shack' look!!
    Quick quesiton, I noticed a lot of those solar tiki lights, do you like those so far?
    Great pool!!
    My pool works thanks to TFP
    Please support the site! pages/supporters/
    It's cheaper than your first trip to the pool store!
    how fun!!
    8000 gallon 20' x 48" round vinyl frame pool, 12" sand filter (don't have the specs on the pump), TF100 test kit
    Handy Links: PoolMath, TF-100 Test Kit, Pool School, CYA-Chlorine Chart
    West Michigan
    I love the look. It looks very vacation like. Kimrst
    5 years 18' Intex Frame pool, July 2009 upgrade, 28ft rnd used Doughboy, 1hs Hayward Power Flow pump, Doughboy DE filter.TF test kit
    The solar lights are gorgeous at night. They have a fairly bright flickering light that is very realistic. However, they do not seem durable. They chip and fade. I hope we can get a couple of years service out of them. We plan to install low voltage lighting later.
    BTW, Moderators, this thread may need to be moved to the Show off the Pool section. I think I should have started it there. Oops, sorry.
    wipple's Avatar
    Jun 2007
    Long Island, NY
    The bathroom in the shack, how did you set that up. I am looking to convert a 10 x 10 shed into a bathroom/changing room and would like some ideas.
    My Pool:
    18 x 33 Johnny Weissmuller
    Hayward EC 50
    Hayward 1.5 2 speed pump
    Great design! I love the Pool Shack.
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    The plumbing for the restroom of the pool shack was installed before the foundation was poured. We had a sewer pipe that ran close to the shack, so it wasn't too hard to tie the toilet and sink in to it. We built a stall around the toilet,which hides the toilet from your view as you enter the shack. Of course, the stall is built out of cedar pickets. The toilet is a one peice unit, and the small sink hangs from the wall. The Pool Shack is 6 x 18, and the restroom dressing area is about 6 x 8. Its really simple, but very functional. The shower is outside the pool shack on the right side. It came from Walmart's online store. It is connected to a water faucet. We don't have any hot water. Hope this helps.
