Rain Rain Rain - SO....
DMS2014
811
Houston, Texas
...What should I do about the chems? pumping water out every day. so far all is good but for the FAC which was low -2. I dumped some bleach in.
The CH was 325
CYA was 70
TA was 90
pH looked sky high but I want the husband to double check me. Is there another test that I can buy for testing? I hate the subjective what color do you think it is?
I feel like if I add anything it's almost a waste and it's gonna rain, I hear, for two weeks!
Advice, please.
DMS,
Well, rain or not, you need to keep your FC up. If I read signature correctly this is a Saltwater pool..
You need to target about 5 ppm if your CYA is 70. Are you saying you measured an FC of 2 or -2?
Seems like you need to adjust the % of SWG output up a little, or manually add chlorine,
Even with a lot of rain, I doubt it will have a major impact on your FC in a 19K pool.
Jim R.
Keep the chlorine in the correct range for your pool or it will go green on you, even with all the rain. I would bring the pH down too as it can cause problems if it is too high for too long. As for the rest of the values I would wait until we start to dry out a little before adjusting them.
