Thread: Rain Rain Rain - SO....
    Jun 2014
    Houston, Texas
    475
    ...What should I do about the chems? pumping water out every day. so far all is good but for the FAC which was low -2. I dumped some bleach in.
    The CH was 325
    CYA was 70
    TA was 90
    pH looked sky high but I want the husband to double check me. Is there another test that I can buy for testing? I hate the subjective what color do you think it is?
    I feel like if I add anything it's almost a waste and it's gonna rain, I hear, for two weeks!
    Advice, please.
    19k SW IG
    Wet Edge pebble tech = new 5/16 (replaster)
    Hayward variable speed pump (new 6/17) /Shark for cleaning
    New - filled 10/18/14 - TFP 100 test kit
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,479
    Re: Rain Rain Rain - SO....
    DMS,
    Well, rain or not, you need to keep your FC up. If I read signature correctly this is a Saltwater pool..
    You need to target about 5 ppm if your CYA is 70. Are you saying you measured an FC of 2 or -2?
    Seems like you need to adjust the % of SWG output up a little, or manually add chlorine,
    Even with a lot of rain, I doubt it will have a major impact on your FC in a 19K pool.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Keep the chlorine in the correct range for your pool or it will go green on you, even with all the rain. I would bring the pH down too as it can cause problems if it is too high for too long. As for the rest of the values I would wait until we start to dry out a little before adjusting them.
    Love TFP? Become a
    TFP Supporter!
    Jun 2014
    Houston, Texas
    475
    I don't know where that - came from on the FAC. The chlorine was 4 five days ago and today 2. it just so irritates me. We seem to always go up and down. I put some chlorine in.
    19k SW IG
    Jul 2015
    Clearwater, FL
    83
    Check your salt level, too.
    16K gallon IG exposed aggregate pool with Aquarite SWG T15 cell, Hayward C1750 filter, EcoStar SP3400VSP pump, H400FD pool/spa heater, Polaris PB4-60 booster pump, 280 pressure cleaner, Hayward Super II spa pump and Air Supply Silencer spa blower
