Results 1 to 16 of 16
Thread: Dolphin will not climb the walls
    Apr 2016
    SW Chicago/IL
    56
    We have a Dolphin Oasis Z5 (very similar to the M500 and M400). I have tried all of the different positions on the handle floats, and still cannot seem to get it to climb our walls. It will go vertical, but just will not get off the floor. I have read a few other places that water chemistry and the robot's filters can also effect wall climbing, and have tried playing with those to no avail. I am thinking it may be that the pool is fiberglass and the sides are just too slick for it to grip? Just wondering if anyone has any other ideas.
    15,000 gal fiberglass pool with built in spa and tanning ledge (Leisure Pools Ultimate 35), Pentair Intelliflo VS pump, Intelliflo XF spa pump, Pentair 250k heater, Easytouch 8 with Screenlogic, Pentair IC 40 SWG, Pentair Clean and Clear 420 cartridge filter, 4 GloBright Pool Lights, 1 GloBright Spa Light, Coverstar Auto Cover, Interfab X-treme 2 Slide, 4 deck jets, Dolphin Oasis Z5 robotic cleaner, TF-100 test kit.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,461
    Re: Dolphin will not climb the walls
    Chris,
    I suggest you call Maytronics and see what they have to say.. Sounds like it is bad to me.
    In their aid they say it works on the following "Surfaces: Vinyl, gunite/concrete, fiberglass, tile"...
    Is this a brand new unit? Has it ever climbed (or even tried to climb)?
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Apr 2016
    SW Chicago/IL
    56
    It is a new unit and we started using it in mid June when we finished the pool. I have been getting used to everything else, so I did not pay too much attention until recently. I have not called Maytronics yet, but have just looked at their troubleshooting page. I am hoping to get a chance to call later this week.
    It does try to climb the walls, as it goes vertical, but just cannot get off the floor. The brushes just spin, then stop and it backs up. It does makes it onto the first step, but that's it.
    Thanks for the help.
    Jul 2014
    Bedford, TX
    7,461
    You do know that it does not climb the walls on every pass. I don't remember the exact count, but it only climbs up the wall once out of every 5 or 6 passes.
    Dec 2014
    Sydney, Australia
    43
    Just a thought, I have a Zodiac, it has 2 modes, one it climbs the walls, one it does pretty much what you describe, it also doesn't like climbing when the bag is full
    8M x 4M Inground Concrete, 40k Litres, Waterline Tiles/Quartzon, Viron P320 VS Pump, Sand Filter(Glass Media) Astral VX-9 SWCG, Heatpump w/ Solar Cover. Zodiac V3 4WD Robot. Bullfrog A8D Spa(1800Litres).
    Jul 2014
    Bedford, TX
    7,461
    just to follow up on what Dibbler said above. Your unit does have a "fast" mode and the instructions say.. "•When choosing the fast cleaning cycle the pool cleaner will not climb walls."
    Do you have the remote? Might want to make sure you are not in the fast cleaning mode.
    If this were my problem, my wife would be saying to me, in a sarcastic voice... "Instructions? I don't need no darn instructions" ..
    Dec 2015
    Newington, Connecticut
    113
    check the impeller. The water flow is used to push the not to the wall for traction
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    Quote Originally Posted by Andrew Howard View Post
    True dat. My wife noticed that our S300 was not climbing the other day. Sure enough the impeller had several strands of hair caught inside which impeded its free rotation. The strands were the same color and length as my wife's. Hmmmm....
    Geebot
    Chicago, IL
    Apr 2016
    SW Chicago/IL
    56
    It has never climbed, so I doubt it is the impeller but will check anyways. I forgot about the different modes, as I don't typically use the remote. I will have to check if it got into fast mode somehow. Thanks everyone for the help. I'll try to play with it again after work tomorrow.
    Do you plug it in and then just hit the "on" button? If you hit "on" and then the cycle button you will change from default to a different cycle.
    Geebot
    Chicago, IL
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Another thing you might try is replacing the brushes and the tracks, as they get older they get less pliable
    Pflugerpool's Avatar
    Jun 2014
    Pflugerville, TX
    65
    Quote Originally Posted by Isaac-1 View Post
    Since the OP bought it in June I suspect the components are probably OK. Like other posters though, I'd almost bet it's set for "Fast Mode." Mine does exactly what's described when it's set to fast - it hits a wall, goes vertical, and then reverses. Also, mine doesn't like climbing with the pleated paper filters installed. It does better on the walls with the screen filters. I guess the pleated filters don't allow enough flow volume to keep it stuck to the wall.
    15,000 gallon 16x30 IG w/vinyl liner built in 2006, Hayward cartridge filter, Hayward 1HP Single Speed pump, Taylor K2006.
    Apr 2016
    SW Chicago/IL
    56
    I got a chance to play with my robot during lunch today, and you guys were right, it was on quick clean mode. My control box only has an on/off button and the mode is set on the remote (one of the differences between mine and the M500). I have always just used the on/off and assumed it was the full clean setting. Changed the setting on the remote and up the walls it went. I did check the impeller as well, and while I do not think it was impeding anything, there was more hair than I though there would be. I will have to check it more often.
    Thanks again for the great support from everyone.
    Sep 2016
    Arkansas
    437
    Glad I found this thread. I too just hit the square power button. Didn't even realize it had different modes as mine wasn't climbing walls either. Thanks for clarifying this!
    17'x35' 22,500 gal. Gunite IGP 3.5-8.0 ft. IC60 SWG, 2 skimmers, 2 main drains, 4 returns. CCP520 cartridge filter, 3hp IntelliFlo 2 VST VSP, EasyTouch 4, ScreenLogic2, 2 IntelliBrite Color LEDs, Poolmiser autofill, UltraTemp 120R H/C 125K BTU heat pump, Diamond Brite Super Blue, No spa or water features.
    Jul 2014
    Bedford, TX
    7,461
    Miles,
    They generally don't climb the walls on every pass either... I forget the exact ratio, but I believe that they only climb once out of every three passes or so.
