Hello Everyone!
We just moved to AZ and I am a first time pool owner and I am trying to play catchup. The pool turned a little green a couple weeks ago and I tested with my old test kit and it hardly had any chlorine left, so I added a quite a bit of liquid chlorine and have been adding some almost daily as needed. I also have been adding some muriatic acid to lower the PH and the pool has become much clearer. The SWG is on its last legs and I have been adding extra chlorine to make up for it's poor performance. I'm thinking I will buy another SWG generator early next spring and use it seasonally during the late spring through early fall. I would like to understand more of what my pool needs and try to schedule additives and regular maintenance as needed which is why I bought the TF-100 and it's great. We have three kids and because of this the pool is being used heavily.
Please take a look at my initial readings and see if anything stands out.
Thank you all in advance
Ryan
My initial results with my TF-100
FC 1
CC .5
T 1.5
CH 200
TA 310
CYA 90
CL .5 (added more liquid chlorine after test)
PH 7.2
Ryan
FC 1
CC .5
T 1.5
CH 200
TA 310
CYA 90
PH 7.2
