Results 1 to 8 of 8
Thread: Intex Ultra 18 sand pump breaker gets tripped w external timer or power fail, mod?
    Jun 2016
    Pittsburgh, pa
    367
    I have the 2800 gallon or so sand pump with the pool, as well as the salt water pump. I thought i could get around the issue of times when backwashing or vacuuming is needed and the pump needs shut off, losing the built in timer setting.. by using a separate timer.. and toggling the on/off mode when such maintenance was needed..
    I could have sworn the pump was coming on and off just fine with this timer, but maybe not.. i think it just was on 24/7 because when i fine tuned things and tested it over night after being off.. the next morning the sand pump wasnt on even though the salt pump was lit up.
    It seems if you kill power to it or use another timer, the reset breaker gets tripped and you have to push it to get it to come back on.. (the intex saltwater system doesnt have this issue).
    Has anyone found a workaround for this or maybe a mod to the plug.. Is this normal for this intex sand pump to get tripped on power failure/timer shut off?
    Thanks for any suggestions.
    domct203's Avatar
    Jun 2015
    CT
    3,593
    Re: Intex Ultra 18 sand pump breaker gets tripped w external timer or power fail, mod
    Quote Originally Posted by theskyisthelimit99 View Post
    This is normal behavior, and I believe it's normal for any GFCI type plug.
    I cut off the GFCI plug and installed a standard Edison plug. I have my timer (and solar controller) plugged into a GFCI outlet, and the pump plugs into the timer.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2016
    Pittsburgh, pa
    367
    Quote Originally Posted by domct203 View Post
    My main outlet outside is GFCI.. is there a certain type of plug you used.. i have one that you can wire the bare wires into directly, but i'm not sure if its rated for out door use or if that matters? My timer hangs down under my outlet with the cover, so the plug would be exposed.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,548
    I had to do the same thing. I just cut it off and put on a normal plug. My timer has a cover over the outlets to protect the plug from the weather.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    I also removed the GFCI from my pump and put a normal end on it as it plugs into a GFCI outlet due to this issue.
    Under Construction - Coleman 18' x 48" Above Ground Pool (6200 gal)
    Intex Krystal Clear Sand Filter Pump, 14", 2800 GPH
    Sioux City, IA
    domct203's Avatar
    Jun 2015
    CT
    3,593
    All my electrical is inside a weather resistant box that I bring indoors for winter:
    The box on the top left gets its power from a nearby GFCI outlet. The box on the bottom left is where the pump plugs in, and that box plugs into the digital timer in the center, and is also connected to the solar controller on the right.
    Dom - TFP Guide
    Jun 2016
    Pittsburgh, pa
    367
    Thats a nice box you have going on there.
    In my case I just have three dual outlet receptacles, with boxes over them, the clear kind.. one of which has the timer, which has to hang down on the outside.. these all on the 6" part of my deck thats below the flooring in the back corner on the outer edge.
    I wasnt sure if this is the right type of plug or not.. i'm pretty sure i have one like it at home already..
    Amazon.com: Hubbell Insulgrip Heavy Duty 5-15P Edison, Male Plug, Black (HBL5266CM2): Musical Instruments
    Any harm in having it outside off the timer in the weather.. or should i find some way to at least cover it alone if possible..
    domct203's Avatar
    Jun 2015
    CT
    3,593
    That's a good quality plug.
    I would give it a go as is, but keep an eye on it incase water does get into something and trip the GFCI.
    Dom - TFP Guide
