Thread: FINALLY got my pool BLUE!!! Now, I have one more question about getting out sand. :)
    Jul 2016
    Comer GA
    25
    Hey guys! I haven't posted in a very long while, but if you saw any of my other threads from earlier this summer, I was dealing with a murky swamp and we've fought a long, hard battle to get our pool in shape! I had given up when it finally started to clear up and now we have a beautiful, sparkly blue pool! I've continued to vacuum the last of the leaves and debris out of it. There were leaves, dirt, rocks, and sticks all on the bottom. After days and days of vacuuming and running the filter that's all gone. Now I have some sand left on the bottom. I think it's coming from my well, as we have constantly drained and filled (simultaneously) for the better part of the summer, putting in fresh water and getting the CYA down. Our well is still new and very deep and we tend to get a lot of sand out of it still. However, my pool vac just doesn't seem to vacuum it up well. I can go over it a couple times and it doesn't seem to make a difference. Any suggestions?? I also have an Aquabot. It's missing a drive belt and I can replace that. Will the Aquabot do a better job than my vac at getting up the sand? TIA!!
    34,500 inground pool with vinyl liner
    Pool approx 17 years old
    1.5 hp hayward 2 speed pump with sand filter
    Mostly sun all day with large oaks surrounding that like to drop their leaves in the pool
    Well water supply
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: FINALLY got my pool BLUE!!! Now, I have one more question about getting out sand.
    My TigerShark picks up sand fairly well, although I've only had a little bit on the bottom at one point. If your vacuum head is not working well, try isolating all suction to just the skimmer you're vacuuming with. Then swim down with the bare vacuum hose and see if that concentrated suction pulls it off the bottom.
    Isolated Spa - 345 Gallons
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    I have a suggestion, try adding pantyhose to the end of the fill hose. This should help keep sand from entering the pool.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Feb 2011
    Petaluma, Ca
    665
    Quote Originally Posted by Ashleigh View Post
    It may be your pump is to close to the bottom of the well, when ours was drilled to 280', the pump was set at 220' so there is plenty of water below it, the water level in the well is 60', never get any sand.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
