Thread: Electrical conduit for pool solar lines
    Jan 2016
    76
    I am debating on using sched 40 electrical conduit for my pool solar (water) feed lines on the roof. It is a little better suited to harsh UV that we get here in AZ, and should be fine under the relatively low pressure. Just wondering if there is something I may not be considering by going this route.
    Jun 2016
    Martinez, CA
    207
    Re: Electrical conduit for pool solar lines
    Normally it will turn brown if exposed to full sun for awhile.
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
    Zappafan's Avatar
    Aug 2014
    Hampton, IL.
    151
    Opposed to cpvc? Typically a cpvc or poly-tubing is used especially in high exposer areas.
    17K Gallon,IG Vinyl,1hp Pentair Challenger,Pentair TA60 Sand Filter, Hayward Colorlogic,Re-lined 06-20-15, TF-100,SpeedStir,Lagunitas and Margaritas. Zappafan Pool Build
    Apr 2013
    Sacramento, CA
    2,769
    Many use cpvc or paint the lines. Mine are painted black on the roof and to match my house as they drop down.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yeah, just use white PVC and paint them. You'll want them to match the house anyway.
