Thread: Sub-panel installation dilemma
    Aug 2016
    atlanta, GA
    12
    Trying to figure out the best placement for my sub-panel and reading electrical codes did not provide a clear answer. So, here is the situation:
    1. Equipment pad is about 25' from the house (main panel is also about 25' away - just inside the wall on the side of the pool).
    2. I am running 1.5HP VS pump (about 8amps at 240V), chlorinator, gas heater (0.3amps) and two LED lights.
    3. planning to put 30AMP double GFCI for the subpanel which should be plenty.
    I have two options for the sub-panel location:
    1. Install the sub-panel next the main panel inside the basement and then run lines to the pump (240v requires 14Gauge wires up to 50' per installation manual) and couple 110V lines for everything else.
    2. or run a feeder line to the sub-panel mounted at the equipment pad.
    I prefer the first option (indoor sub-panel installation) but wanted to make sure I am not overlooking something or violating any codes?
    thanks
    Mike
    17 by 12 by 5 in-ground pool. Total of 8,000 gallons. Picture is coming soon.
    Jul 2015
    Central Valley CA
    1,109
    Re: Sub-panel installation dilemma
    You must have a disconnect within sight of the equipment so you might as well put the sub panel at the equipment pad, it will also cost less since you will be able to run fewer circuits/conductors back to the house. Take a look at THIS
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Are you installing automation?
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Apr 2013
    Sacramento, CA
    2,769
    Best Practices is to install a sub panel next to the equipment so it can act as a disconnect (it must have less than six throws). If you are installing automation it may include a subpanel in the control box.
    Aug 2016
    atlanta, GA
    12
    Yes, I was planning on installing automation - i guess I will go with the sub-panel on the outside. Thanks for your advice.
