Results 1 to 9 of 9
Thread: What kind of shop vac to blow out lines?
    Jul 2015
    Independence, KY
    14
    How powerful of a shop vac do I need to get to blow out lines when closing? We used my dad's last year and it didn't get the bottom drain all the way out. Never saw air bubbles coming out. My husband said it's fine because we blew them a long time but I worried all winter about it. It was fine but I want to make sure we get all the water out. I have no idea what kind to buy.
    16x32 inground vinyl pool, 23,000 gallons, Hayward sand filter, built 2013, Taylor K2005 test kit, Dolphin cleaner
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: What kind of shop vac to blow out lines?
    I use a small pancake compressor as my shop vac did the same thing as yours. I just turn the compressor regulator down to about 20 psi and thread it into the pump basket. Works fine for me and our pools are quite similar. Sorry I can't recommend a size for you.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    May 2013
    Long Island NY
    419
    I also do it the same as pool Tool. Shop vac just don't work for a lot people, some they do.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    I use a small compressor as well, dialed down to 20 psi. I take the pressure gauge out of filter and blow from there. That is how my PB did it and it worked fine.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Compressor for me as well. I can blow out everything but the main drain with my shop vac. Main drains require pressure and some air volume to blow out. Shop vacs are good at air volume, but not when under pressure (resistance). Compressors are great at building pressure, but not so much on volume. The cyclone blowers designed for winterizing pools and installing liners are a good blend of both pressure and air volume.
    Isolated Spa - 345 Gallons
    Jul 2015
    Independence, KY
    14
    What kind of attachment do you use?
    Pool Tool's Avatar
    May 2014
    757
    The standard 3/8" air hose usually will screw right into one of the pump basket drain holes. Just remove one plug, thread the hose in then connect house to the compressor. Set the compressor regulator to 15 psi to start then increase as you need to to blow main drain.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,255
    If you wish to get a little creative and do not have a budget, you may consider purchasing a Cyclone Pool Blower and creating a modified cover with an adapter. Total cost is around $425-$450 (if you have a Hayward Super Pump). I will send you the links later as to what I have done, and it will provide you all the part #'s, etc. and where you can purchase everything. If not, the pancake compressors appear to do a really good job.
    From where were you planning on blowing air through?
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Sep 2014
    Bethlehem, PA
    16
    I'll second the reply from Catanzaro. Years ago I bought the biggest baddest shop vac I could find (since I needed a shop vac at the time). It produced one bubble from my bottom drain after several minutes of blowing. Then I rented smaller air compressors from a rental place for several years ... never got around to buying one. Then my neighbor bought a Cyclone Liner Vac. They produce LOTS of air volume but not a lot of pressure (kind of the opposite of an air compressor). But let me tell you, it REALLY blows out the lines ... lots more bubbles and air coming out compared to an air compressor (especially when the compressor air tank runs out of air and you're just blowing on the produced air). Only downside is it cost around $325 on the internet (bought my own a couple years ago). So while an air compressor does OK, I just love the Cyclone Liner Vac. I disconnect my equipment (have unions on everything) and I use my pool vacuum hose connected to the liner vac to blow out the lines.
    Gunite 21,500 Gallons, Diamond Brite Finish applied 2015 (pool built 1995), Pentair Superflo VS 342001, Hayward DE 4800 Filter, Polaris 360 Pool Cleaner, Heat Siphon Z575HP Heat Pump, TF-100 Test Kit with SpeedStir
