Results 1 to 7 of 7
Thread: Sock filter in skimmer basket, use or not?
    We have received advice from our PB to use the sock in the skimmer basket, and then we were told by the pool supply store worker not to, as it increases pressure on the system. Can someone give me the scoop on this. Thanks a ton.
    16 X 32 Vinyl. Hayward aqua rite salt system, T -15 cell. Hayward H250 gas heater, Hayward 1HP superpump.
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: Sock filter in skimmer basket, use or not?
    I use skimmer socks in mine. Rinse it out with a hose when it gets dirty. When the pollen is flying I do this twice a day. Its amazing how much stuff they catch. Keeps it from entering filter, longer time between backwashs for me. Knee high stockings work also.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by DaveNJ
    What he said.
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    This is prob a stupid question but is there a certain type of knee high that you use?? Are some thicker than others??
    18ft. Arcadia Round AGP - 19" Sand Filter, 1 hp pump
    Foam cove/ Gorilla Pad/ Wedding cake steps
    Sta Rite Lil' Shark cleaner and Aquabot Pool Rover cleaner - Aqua-Luminator light and return flow w/fountain attachment
    Added Borates 5/19/09 Taylor K-1005 and Taylor FAS-DPD Chlorine Tests
    DaveNJ's Avatar
    Toms River, NJ
    520
    Find ones with the finest weave you can.
    Jun 2007
    NC
    255
    Quote Originally Posted by jonmar
    ...advice from our PB to use the sock in the skimmer basket...told by the pool supply store worker not to, as it increases pressure on the system...
    Use either skimmer socks or ladies knee-high stockings. Both work, the skimmer socks probably catch slightly more gunk (but not much more), the knee-high's are cheaper: you just pitch them rather than washing them. 8)
    Increases the pressure on what? The skimmer is on the suction side of the pool. Unless it's your only supply back to the pump AND it clogs the skimmer there shouldn't be a problem... Just check it when you check the water levels!
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
    Guest
    I have found a significant difference between the amount of gunk caught by knee highs and skimmer socks. Simmer socks do a MUCH better job, IMHO, expecially during pollen season.
