Thread: Rough vermiculite floor
    Nov 2015
    Orange Park
    14
    I just finished troweling the vermiculite for for my ig vinyl liner pool. It still has some high spots that need to be knocked down and some low spots to be fill but overall I am happy with the way it turned out. My only concern is that the surface is kind of rough to the touch. Is this normal or is it supposed to be smooth like regular concrete? I was thinking about using an orbital sander to smooth it out a bit. Has anyone tried this or is it not necessary? Thanks in advance for any help.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,575
    Re: Rough vermiculite floor
    When you say rough to the touch just how rough are you talking about? To me concrete is rough to the touch so........
    I would use great care with the sander. A very light touch and almost no pressure. Please tell me you are talking about a small, hand held one. NOT one of those huge monsters they do floors with. The big one would ruin all of your hard work I fear
    Nov 2015
    Orange Park
    14
    Quote Originally Posted by kimkats View Post
    It feels like a rough sand paper. The surface is just not slick like a finished concrete, it is more like open pores.
    Was going to use a hand sander. A large floor sander would be faster but i think it would remove to much material too fast.
    Thanks.
    Feb 2012
    Maryland
    400
    It absolutely wont be slick like finished concrete. What did you use to trowel? Using a "pool float" should give you the correct finish.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    Nov 2015
    Orange Park
    14
    Quote Originally Posted by ssgumby View Post
    I used a pool float. I just wanted to be sure it wasn't supposed to be slick. Thanks.
