Thread: Filter Pressure rises quickly
    I've got a 48 sq. ft DE Filter on a 13000 gal pool. If I completely break down the filter and add new DE I usually get a starting pressure of 8 psi. The problem is that the pressure can rise all the way to 30 psi in about 3 days if I leave the filter. Now I admit that I don't have the cleanest pool on the block but it is no swamp either.
    I notice that if I shut off the pool pump when the pressure is high for say an hour and then turn it back on the pressure will start off at a normal psi and then fairly quickly rise to a higher one.
    My question is: How long should a round of new DE last? 2 days , 2 weeks 2 months?
    thanks
    ktdave's Avatar
    Katy, TX
    888
    Re: Filter Pressure rises quickly
    I'd suggest to try replacing your pressure gauge. Some will wear out quickly. They are fairly inexpensive and are easy to install.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
