Thread: Should I plug the second hole in the skimmer box or unplug the outlet?
    Mar 2016
    Cleveland, TN
    6
    I have two holes in the skimmer box and an outlet that is plugged which is below the skimmer box. I don't have a drain so what is the purpose of the second hole and outlet? Should I plug the second hole or unplug the outlet?
    Still wet behind the ears pool owner
    34 x 18 27,500 gallon inground Buster Crabbe vinyl, one return, built in 1994
    Haywood Pro-Series S244T Filter
    Utilitech 1HP Themoplastic Pump UT1100IGPP
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    Re: Should I plug the second hole in the skimmer box or unplug the outlet?
    That is an equalizer pipe, it is used to allow water to flow to the pump if the skimmer gets blocked or the water level drops too low.
    Mar 2016
    Cleveland, TN
    6
    So I should take the plug out of the outlet to let it do it's job?
    DFW, TX
    24,492
    Sure, no reason not to.
