Thread: Total chlorine
    Aug 2016
    Houston, TX
    19
    Re: Chlorine/CYA relationship
    I realize this is an old thread, but it came closest to what I am searching for so I will resurrect. After reading chem geek's post about active vs. bound (to CYA) chlorine levels here, I was curious what our test kits are measuring. When I get a reading of 4...is that TOTAL (bound and unbound) or just the unbound/active level? Since I haven't come across any debate about this, I assume it is the total...but wanted to confirm since I did not know if the reagent would react to "bound" chlorine or not.
    13.5k gallon IG gunite
    200sf Pentair C&C cartridge
    Pentair SuperFlo 1.5HP dual speed
    Rainbow 320 (vacation chlorine)
    Built in 1999, re-plastered and re-coped in 2013
    JoyfulNoise's Avatar
    May 2015
    13,231
    Re: Total chlorine
    The DPD-FAS test measures both free chlorine (FC) and then combined chlorine (CC). Free chlorine is made up of three components - hypochlorous acid (HOCl), hypochlorite anion (OCl-) and chlorine bound to CYA (HCy-Cl). HOCl/OCl- are considered active chlorine and the HCy-Cl is bound or reserve chlorine. So when you measure FC with your DPD-FAS test, you are measuring all of the active and reserve chlorine in the water.
    Matt
