Thread: Backwashing in the rain
    May 2016
    Austin, TX
    29
    We're getting some significant rain and I'm looking at having to drain some water out of the pool this evening. I haven't backwashed in a while and the pressure isn't super high but it's high enough that I figure I might as well take this opportunity to backwash rather than just wasting the water. I'll probably be doing it in the rain. However.. adding DE to the skimmer is going to be a bit awkward in the rain, while holding an umbrella in one hand. Is it dangerous to run the filter after backwashing without adding DE right away? Or should I make sure it stays off until I can add DE? I usually let it run overnight.
    Pool Stats: 15k gal IG plaster, Pentair FNS Plus 60 DE filter, Pentair WhisperFlo pump, Pentair Legend Platinum pressure cleaner w/ Polaris PB4-60 booster pump. Test Kit: Taylor K-2006
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,481
    Re: Backwashing in the rain
    You do not want to run your pump very long without DE in the filter, so you need to add DE pretty quickly.
    I think your problem is how you are adding your DE.. My guess is that you are adding dry DE to your skimmer.
    Try this in a covered area... Take an empty five gallon bucket and put the amount of DE you want in your filter in the bucket. Add water until it is almost at the top of the bucket. (You'll be amazed at how much water you can still put in a bucket, even if it almost full of DE.) Mix the DE and water into a slurry, and then slowly pour it into the skimmer with the pump running.
    Doing it this way works best for me and it does not matter if it is raining or not.
    KatyTXPoolOwner's Avatar
    Jul 2015
    Katy TX
    90
    I bought a stainless steel paint mixing paddle and attached it to my drill. MUCH easier to mix the DE and water into a slurry.
    23,000 gallon gunite chlorine pool / spa .. French Gray Pebble Sheen .. IntelliFlo VF main pump .. IntelliFlo VS spa booster pump .. WhisperFlo 1HP water feature pump .. LA01N .75HP cleaner booster pump .. Letro Legend Platinum cleaner .. Quad DE 100 filter .. Max-E-Therm 400k heater .. Rainbow 320 chlorinator .. 1.5HP blower .. Easy Touch 8 remote control .. 8 Twirlybyrd jet spa .. Paralevel .. TF-100 w/SpeedStir
    May 2016
    Austin, TX
    29
    Thanks for the tips! Unfortunately I don't have a big bucket, but I ended up not needing it. There was a break in the rain and I managed to get everything done without issue. Something to keep in mind for the future, though!
