Thread: TA too high
    Jul 2008
    Seacoast, NH
    253
    TA too high
    My TA was very very low, so I added baking soda. I added only half the amt from the pool calculator, but I must have entered something wrong or tested wrong originally, because now my TA is 150. Here are my numbers
    FC 5.5
    CC 0
    TA 150
    CH 100
    CYA 40-50
    I'm working on getting the CYA up to 60 and the TA down to 80. As you know, getting the TA down is a long process. Is there any problem with taking a few weeks to get the TA down?
    Thx.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Guest
    Re: TA too high
    No but it doesn't have to take that long if you have a good way to aerate. Just keep your pH at 7 while you aerate and keep checking the TA until it's on target and then stop adding acid and just aerate until the pH rises. From where you are now it should take no more than a few days! If you want to do it slowly then just lower your pH to 7, don't worry about aeration since the pH will rise on it's own, just slowly. Whenever the ph rises above about 7.8 lower it back down to 7.0. This will eventually lower your TA but it will take weeks!
    However, since you have a SWG I would recommend doing it the first way since you don't want to accidentally create scaling conditions by a pH spike. Also, shoot for 80 on the CYA instead of 60. Just use the pool calculator to determine the amount needed, put it all in and test it in a week. Don't even worry about it for a week since the full amount can take that long dissolve and be readable.
    these two threads might be of help:
    how-to-lower-ta-t5341.html
    water-balance-tips-for-a-swg-t3663.html
