Results 1 to 15 of 15
Thread: Trouble with CYA test - water remains clear
    Aug 2016
    Madison, Alabama
    5
    Hey folks, I just got a new vinyl pool liner and filled the pool up with tap water (city water). It filled up last night and I performed the first test just now (next afternoon). Everything looks good except for the CYA.
    When I mix the pool water with the R-0013, wait 30 seconds, mix and then pour into the tube, the mixed sample is perfectly clear. There is no amount that I can pour in there to make the black dot fade out. This would mean that my CYA levels are through the roof right?
    The R-0013 reagent is only 3 years old (or so) so I'm not sure that it's gone bad. Surely the water from the city should have 0 CYA right?
    Thanks in advance for any help!
    Cary
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Trouble with CYA test - water remains clear
    IF your result is clear, then you have little to no CYA in the water.. Your reagent is definitely old so you prolly wont get conclusive results
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Aug 2016
    Madison, Alabama
    5
    Thank you for your response.
    You are correct and I have made an error. I *assumed* that the CYA levels indicated on the side of the tube went *up* as the level goes up. They go *down* though. This would indicate that my CYA level is close to zero, which is what I would expcet. My bad. Sorry folks. You'd think I'd never done this before. <sigh>
    Cary
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Time to get some stabilizer in a sock in front of a return. If you knead the sock it will dissolve quicker. Still need to give it a few days from the time it fully dissolves from the sock until you retest.
    Solar Blanket, Well Water, Borax Added. 68
    Mar 2016
    South Bend, IN
    198
    Quote Originally Posted by Kiss4aFrog View Post
    I second this post!! This is what I did (I actually put two socks in one on each return jet) and even kneaded both for about 5 mins each, they were both dissolved in about 20-25 mins.
    In-ground Rectangle Pool
    Gallons: 28400
    Pentair TA60 Sand Filter (Installed April 2002)
    Purex Triton Pinnacle High Perf Pump (1HP single speed I believe)
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Quote Originally Posted by Blcnghtsky View Post
    May 2012
    Toronto, ON
    463
    Is it ok to put the sock in your skimmer basket as well?
    Vinyl 18'x36' in-ground 100,000 L, Jandy Aquapure 1400 SWCG, Jandy Lite2 heater, StaRite System3 filter, Evac tube solar heating panels
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    It is but we recommend putting it in front of the jet... disperses better that way
    13500 gal
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    If it's in the skimmer basket it's going directly to the filter and sitting there until it dissolves into something small enough to pass through. IF . . . you need to do a backflush within a couple days of adding the CYA some of it might be going out the discharge pipe. If you put it in front of a return it's likely at the bottom of the pool and you're not going to lose it. Can take up to a week for it to completely dissolve which is why they recommend waiting a week to re-test CYA. That way you're not going to get a false reading and saves on using up the reagent.
    May 2012
    Toronto, ON
    463
    I don't backwash as I have a paper cartridge filter and I remember not to open it up and hose it down (which I only do a couple of times per year) within a week or so of adding CYA.
    Aug 2016
    Madison, Alabama
    5
    Thanks! I didn't think of that. Won't I get stabilizer from using regular shock?
    I know I need it, but the reason I replaced the liner when I did was because I got into trouble with CYA. It was too high. I started the process of replacing water but decided that if I need to replace a *lot* of water then I may as well pull the trigger on the new liner. I'm gun-shy of CYA now and was thinking that I could eventually get it where it needs to be with shock and then switch to bleach. Too slow?
    Cary
    30,414
    You can certainly do that if you dose, test, and manage your pool correctly. We don't find folks that always do that very well so TFP "official" suggestion is to adjust CYA with CYA and adjust chlorine with chlorine. Moving two parameters at once seems to cause issues but you are certainly welcome to so that if you feel you can do it properly.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Using the shock to add to your CYA is a slower process but it's a good way to use up any you have on hand. If you don't already have it I sure wouldn't buy it, just get dedicated stabilizer.
    You don't need to worry about getting into trouble with it as long as you understand where it's coming from and that it takes a while for it to dissolve and show up on a test.
    Aug 2016
    Madison, Alabama
    5
    Thank you very much guys!
    I should have said as much but yes, I have shock on hand and want to use it up. After my CYA debacle, I'm sticking to the TFP way when the shock is gone.
    Cary
    Mar 2016
    South Bend, IN
    198
    I did something similar... My CYA was <20 and I had extra tabs (maybe 12-15 3" tabs) so I used them up. Then retested after about a week or so after using the last ones and it wasn't as significant a change... Maybe 20 instead of <20.
    But now that those are gone, I do ha e dedicated CYA and liquid chlorine.
    Gallons: 28400
