Thread: Pump trouble?
    Messman750's Avatar
    Jun 2015
    Groton New York
    34
    Pump trouble?
    I have a Hayward super pump 1hp. The pump is brand new as of last year. The problem I am having is when I shut the pump off to backwash or dump to waste the pump will not turn back on immediately. I have to wait a few before it turns back on. I does set out in direct sun and it has been very warm the past week. It's never shut off on its own due to over heating. It's never done this before?
    32x16 inground chlorine. 23000 gallon with diving board
    vinyl liner 1hp hayward super pump. Waterway sand filter new in 2014.
    maytronics dolphin m200 robot. I live in central NY.
    TF100 kit Taylor speedstir. Sonos audio
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Pump trouble?
    First check to see if anything is stuck in the impeller inlet or the impeller itself.
    Mark
    Apr 2013
    Florida
    29
    Re: Pump trouble?
    When you supply power to the pump to turn it back on, is it silent or does it make a noise?
