Thread: Valve attached to pump, for draining pool?
    May 2015
    Lafayette Hill, PA
    23
    Coming off of my pool pump is a valve with hose attachment (similar to what you would have on your house almost to have a hose hooked up). I noticed the old home owner has a hose laying out here as well. I was never explained what this was for so I haven't touched it and anytime I have needed to drain the pool I have just used my sump pump directly in the pool.
    Is this valve and hose attachment meant to drain the pool when needed for whatever reason (excessive rain for example)? Is it as simple as hooking up the house and turning the valve on while the pump is running? I didn't want to touch it until asking here first. Picture of what I am describing can be found here
    Thanks!
    25,000, IG, Plaster, Hayward DE Filter, Jandy Pool Pump, 2011 install, No SWG
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Valve attached to pump, for draining pool?
    Yep, you've got the right idea there.
