Thread: Installation of Pentair 34004 - HELP!
    Mar 2016
    Cleveland, TN
    6
    My husband is replacing our pump with the Pentair 34004 and has concerns about the present configuration of the plumbing. According to the info from Pentair, 90 degree angles are to be avoided if possible. I have attached photos of what we have now. Do we need to reconfigure the pipes with less angles? His biggest concern is the three 90 degree angles on the pressure side, but as he investigates more, he is also worried about the suction side. We would also like to know the purpose of the pipe circled in red.
    Still wet behind the ears pool owner
    34 x 18 27,500 gallon inground Buster Crabbe vinyl, one return, built in 1994
    Haywood Pro-Series S244T Filter
    Utilitech 1HP Themoplastic Pump UT1100IGPP
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,504
    Re: Installation of Pentair 34004 - HELP!
    If you were trying to make it "perfect" then the number of 90 degree turns might make a difference. But the actual effect is not much at all when it comes to pool pumps. I'd just plumb it the way it is currently shown.
    I have no idea what the extra pipe is. Possibly an unused backwash drain???
