Results 1 to 12 of 12
Thread: Strange fixture in wall of inground pool
    Good morning!
    I am new to the forum, so pls excuse me if I am posting in the wrong place...
    We recently bought a house with an inground pool (first time pool owners, loving it!). I found in the wall this fixture, on two sides of the pool, and not sure what it is for. Does anyone have any idea? There is no water in\out of it, and it is locarted on opposite sides of the pool, right where the deep end starts. So we are thinking it might have been used to connect a net or something between shallow and deep end?
    Any input would be welcome.
    Thanks
    Sam
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,196
    Re: Strange fixture in wall of inground pool
    Welcome to TFP!!
    It appears to be the point where a safety rope is attached to the walls to keep folks who can't swim out of the deep end. Kind of like lane marker ropes.
    Support the site
    Quote Originally Posted by tim5055 View Post
    Welcome to TFP!!
    Thank you Tim.
    Any idea where I could find the mating part? I tried searching using different phrases, but can't find anything like that. I want to try and use it for my tethered swimming cord.
    May 2015
    Mount Cheaha Alabama
    250
    Appears from the picture that one of the rope ends is still in the fitting. Slide it up to the large opening and it should come out maybe you'll get lucky on a part number
    30k in ground vinyl lined pool surrounded by decking in the woods.
    Hayward sand filter circa mid 80's
    If there is a way to do things less expensively and yield a superior product I am all ears
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Welcome to TFP Sam
    Part number or even a manufacturer's name. I tried doing google images but nothing close to it.
    How old is the pool ??
    Solar Blanket, Well Water, Borax Added. 76
    Thanks all,
    Pool is at least 13 years old, i suspect more. Great idea on the part stuck, got it out, but all it said was Anthony and Sullivan. I guess I can try and contact them, hopying they would have something.
    Either that, or I will just end up machining something with similar dimensions...
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,627
    Swimming Pool Supplies, Pool Safety Cover, Swimming Pool Covers, Swimming Pool Pumps, Pool Pump Parts - INYOPools.com
    Try this company. They have awesome cust. service. You can email them a pic and they might be able to help you.
    Tell them TFP sent you for the white glove treatment!
    wjr75's Avatar
    Jun 2013
    IL
    836
    I did some searching online and didn't come up with anything. Keep the part you just took out as you may be able to attach a newer line to it using stainless steel fasteners. We have a pool deep end line and have never used it.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Seems Anthony & Sylvan is a pool builder and they are still around. Pool Equipment and Products | Anthony Sylvan Pools -
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    I will take a photo of my ancient A&S pool (circa early 1980s). I have one of those things between my deep and shallow end, but I'm pretty sure I don't have a matching one on the opposite wall.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    I stand corrected. My pool has two. One on each side.
    Karen
    Quote Originally Posted by kcindc View Post
    Thanks Kcindc. Just realized we actually live in the same area...
