Results 1 to 11 of 11
Thread: Preparing for a big rain
    Jun 2015
    Ottawa/Ontario
    339
    Hi all
    Looking for some advice in advance of a big rain tomorrow - current weather report is saying anywhere from 25-60 mm of rain (1 - 2.5 in).
    I am concerned about the pool overflowing, as well as chlorine levels.
    Should I dose the pool with some chlorine ahead of the event? Should I draw down the water ahead of time?
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,237
    Re: Preparing for a big rain
    Overflowing is annoying in many cases, and can cause damage, so you can pump down using backwash or drain to waste.
    All else being equal but the rain, chlorine is no concern whatsoever if you have your FC/CYA ratio correct before the rain. Both are diluted equally so the ratio remains the same.
    Accompanying wind can bring higher organic load into the pool.
    Draining down ahead depends whether you'll be around to do it during the rain. Some people raise FC because of expected leaves, bugs, etc.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Generally, the only thing an inch of rain does is add an inch of water to the pool and raise PH through aeration. Some folks with high CH or CYA look forward to getting some low CH/CYA water for free. Otherwise rain is a non-event.
    Jun 2015
    Ottawa/Ontario
    339
    Awesome. Thanks both. I will pump down tonight - we had a big rain the past two days and water went above the skimmer line so we pumped down to below. We have about 2 inches to spare, before water goes over pool....so given lack of head room, it seems to make sense to bring 'er down a wee but more!
    Cheers
    Tom
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    May 2012
    Toronto, ON
    463
    Is there any problem with your pool being too full, other than the fact that the skimmer may not work? I normally don't bother pumping water out as I usually have to add water to my pool due to evaporation. So what's the big deal if your skimmer doesn't collect debris for a few days or so? You can manually skim if you care.
    Vinyl 18'x36' in-ground 100,000 L, Jandy Aquapure 1400 SWCG, Jandy Lite2 heater, StaRite System3 filter, Evac tube solar heating panels
    Jun 2015
    Ottawa/Ontario
    339
    Quote Originally Posted by wayner View Post
    No big deal with that...except back to back big rains will cause water to overflow from the pool....
    May 2012
    Toronto, ON
    463
    I would need about 15cm of rain to cause my pool to overflow and that hasn't happened in the 9 years so I have had the pool.
    Jul 2012
    Waterloo, Ontario, Canada
    10
    lol - with the non-accuracy of the rain predictions this summer, I might consider holding off on that unless you absolutely have to! I personally would welcome not having to pay to top off this summer. They say there could be up to 60 cm rain tomorrow in some spots, but I'm not holding my breath....
    21,000 gallons (81,000 litres) inground vinyl, 16 x 32, Hayward S-244T sand filter, Hayward 1 hp superpump - 2 speed, Hayward 250,000 BTU Nat Gas Heater
    May 2012
    Toronto, ON
    463
    Quote Originally Posted by gailn View Post
    ... there could be up to 60 cm rain tomorrow in some spots, but I'm not holding my breath....
    I think that is mm, not cm. An order of magnitude of difference!
    Special Weather Statement
    Issued at 12:04 Monday 15 August 2016
    A significant widespread rainfall event is expected beginning overnight or early Tuesday morning and ending Tuesday evening. Rainfall amounts will range from 25 to 40 mm in most places. There may be appreciably higher amounts exceeding 60 mm in some locales.
    The system responsible for this rainfall is a slow-moving low pressure system from Texas. It will bring tropical moisture from the Gulf of Mexico to Southern Ontario.
    Rainfall warnings may be issued if a more significant event of widespread 50 mm or more appears more certain.
    Please continue to monitor alerts and forecasts issued by Environment Canada. To report severe weather, send an email to storm.ontario@ec.gc.ca or tweet reports to #ONStorm.
    Jul 2012
    10
    lol - you're right of course! My head said mm, fingers wanted cm. Nice to have the water level up naturally for the first time this summer. Might even give me a few days before topping up (splashing and diving dog is not conducive to keeping water in the pool!)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Don't worry about the pool overflowing. The water that comes out of the pool is going to be less than what would have hit the yard if the pool wasn't there.
