Results 1 to 7 of 7
Thread: stinky hot water smell from pool chemicals?
    Jul 2012
    Whidbey Island, WA
    397
    Hi
    So one can get stinky hot water from bacteria in the tank. Ours was recently cleaned. But...
    Do pool testing in downstairs bathroom lavatory.
    Today upon entering smelled no stinky hot water.
    Did FC test and rinsed stuff down the drain. Smelled no stinky hot water.
    Did pH and rinsed stuff down the drain. Smelled no stinky hot water.
    Did CH test and rinsed stuff down the drain and - got a whiff of stinky hot water.
    Is it possible to get stinky hot water smell from pool chemicals mixing in the trap?
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,230
    Re: stinky hot water smell from pool chemicals?
    If there's organics in the floor drain, the pool water or chlorine would create chloramines (motel pool smell)
    I put vinegar or dilute acid down them now and then to kill stuff in floor drains. Thinking about a half pail of pool water for that chore, with an extra teaspoon (5 ml) of bleach. Doesn't sound like yours was dry in the p-trap but that can be a source of odor.
    I would flush the hot water tank really good and if possible, inspect the anode, replace if need be, and have a gander in the tank.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    30,403
    For the life of me, I cannot imagine the volume of pool testing chemistry you use having ANY, ANT effect on your drain smelling, If anything, My assumption it is helping keep it clear.
    Are you saying that you get a smell from the hot water out of your tap or your drain? They are not connected. If the smell is coming from your hot water tap, that is a byproduct of bacteria in your hot water tank......it does not connect to the drain that takes in your pool chemistry.
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by needsajet View Post
    Thanks
    Is not a floor drain, is a lavatory drain.
    Plumber was here last week for annual service and drained bleached the hot water tank. Anode was new last year. We do not have stinky hot water when running the faucets.
    Only time I get a whiff is when doing FC and pH. And so wondered if FC and pH chemicals rinsed down the lavatory drain can make an odor.
    Whiff of odor is in the general area above the lavatory, cannot pinpoint to hot water faucet or drain. But as above, we have no odor when simply running hot water faucets as anode, tank, etc have all be recently cleaned.
    Not a big deal but is interesting. What is my sniffer sniffing?
    Jul 2012
    Whidbey Island, WA
    397
    Lotsa noses have now sniffed. Seems to be just the "fragrance" of the FC and pH reagents, nothing to do with hot water or the trap.
    Jul 2012
    Whidbey Island, WA
    397
    so then two months later answer is out
    what is the answer?
    turns out our septic tank pump was failing and we were getting intermittent burps of septic tank gas
    not hot water, not reagents, rather septic tank whiffs
    needsajet's Avatar
    Jan 2016
    4,230
    Hey thanks for the follow-up. It's good learning for everyone and glad you got it sorted.
