Results 1 to 12 of 12
Thread: Filter leaking at backwash pipe
    Jan 2010
    Northern Virginia
    282
    Hey all -
    Things have been going well this yeah. So well, that this is my first post
    I back washed my DE filter last weekend for the first time this year. (It didn't need it until then). When I looked at it today, there was water leaking out of the "Backwash pipe". I tuned the valve handle from "lock" to "open" and back a couple times, but it didn't seem to affect the flow.
    Anyone have any ideas to what's happening here? Do I need a new valve installed?
    700 sq. ft./30,000 gal, gunite pool; 48 SF DE filter; 1.5 HP pump; Salt Water Generator; Solar Heat
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,515
    Re: Filter leaking at backwash pipe
    Bart,
    A picture of your equipment pad, showing the valve area, would really help us provide the right feedback.
    Jan 2010
    Northern Virginia
    282
    Thanks Jim. Here you go. Let me know if you need any close ups
    (Currently having trouble posting photos from my phone. I'm going to try to do it in a separate post )
    Jan 2010
    Northern Virginia
    282
    Trying to post photos.
    Jan 2010
    Northern Virginia
    282
    Round two
    Sorry for all the duplicates. This phone and the cellular signal are making it difficult.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Looks like you need a Jandy valve rebuild kit. Replacing the O rings will likely solve your problem. Remember when assembling it to use some silicone plumbers lube or specific silicone pool equipment lube.
    Here is some how to video - - > Google
    Solar Blanket, Well Water, Borax Added. 68
    Jul 2014
    Bedford, TX
    7,515
    What a perfect response...
    Jan 2010
    Northern Virginia
    282
    Thanks folks!!
    One more question. I just pulled the valve out and the bottom O-ring was broken. Should I put the good O-ring from the top onto the bottom for the time being? Or will that just cause water to leak from the top? I was thinking/hoping that the seal on the screw top cover might keep it sealed. Probably not though.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    If you have it apart you can always give it a try. Maybe it will leak less ??
    For a very temporary repair you might try an automotive parts store (autozone, Oreilly, ...) as they usually carry an assortment of O rings in a box behind the counter. Not sure they'd have one big enough but if they did you'd only need to buy that one. Just don't count on it holding up.
    You can get the grease at a hardware store or big box store (HomeDepot, Menards, ...).
    Jan 2010
    Northern Virginia
    282
    Thanks! I just made a pool store run and it looks like the top (black) and bottom (blue) orings are slightly different sizes so it probably would have been a disaster if I tried that!
    Jan 2010
    Northern Virginia
    282
    Bottom o ring replaced. Leak stopped. All is well (fingers crossed)
    Thanks all! It's advice like this that motivated me to become a lifetime member.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Your support is much appreciated, thank you.
    It's a great feeling to get in there and repair something yourself.
    Soooo much cheaper too.
