Thread: Losing water
    Jun 2016
    Alton , il
    10
    Losing water
    I have an above ground pool and I'm losing 2-3 inches of water a day . Looked for a leak in the Liner with goggles and food coloring checking any spot that looked as if it could have been a leak . No luck finding one though. Any suggestions . Does this find a leak fix a leak product I've seen work on a liner hole ?
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Re: Losing water
    Any wet spots around the base or equipment of the pool?
    If you didn't refill the pool as it drops its level down, eventually it should stop at the level of any hole/rip on the sides.....sometimes that makes it easier to find.
    Short read--> Pool School - Leak Detection
    Jun 2016
    Alton , il
    10
    Re: Losing water
    Yeah I always have a few damp / muddy spots around one edge , I've let it go below the skimmer .. I was told if I lost all my water the walls would collapse is this true ?
    Jan 2012
    7,373
    Re: Losing water
    No, you wouldn't want it to go *that far*....interrupt the loss before it got that bad. But sometimes just watching a day or so guides you to where to look if the water were to *stop* lowering.
    Jun 2016
    Alton , il
    10
    Re: Losing water
    Any idea if that find a leak fix a leak would work ? I've read a couple reviews where people have used it on liners and it worked . Then some said it wasn't ment for the liner
    Jan 2012
    7,373
    Re: Losing water
    I'm sorry, I don't know anything about that product.
