Thread: Rust stain
    May 2015
    Monroe/NJ
    76
    Rust stain
    Hi all. Inground gunnite pool just over a year old. Small circular rust stain seen on side wall. Something under the gunnite rusting through? Already contacted pool company that built pool but want the truth here before they start the spin and the blame game. Is this a bad sign or a really bad sign?
    Thanks
    Jim
    Inground Pool Completed April 2015
    Salt Water Generator- Nature 2 Fusion Soft
    33,500 gallons, Gunite/White Plaster
    Cartridge Filtration
    Heat Pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,512
    Re: Rust stain
    Your sig says white plaster. That looks like blue pebble. It could be a contaminant in the pebble mixture. It happens occasionally, we had one. PB dug out the rock, that wasn't a rock, with a screwdriver and filled the hole with pool putty.
    May 2015
    Monroe/NJ
    76
    Re: Rust stain
    Thanks. Yes it's a gunnite mix. Not sure if the nomenclature they never said pebbles but it is a mixture to give the pool surface a slight blue hue. Hopefully that's all it is...thanks
    Heat Pump
    Apr 2013
    Sacramento, CA
    2,769
    Re: Rust stain
    That's obvious enough that it should have been visible prior to plaster. So if you saw nothing there prior to plaster it is very likely in the plaster.
