Thread: Cloudy pool won't clear.
    New Jersey
    Am helping a neighbor with pool, but having a problem getting it clear.
    Pool was green with algae when closed in fall, CYA was over 100.
    Opened this spring to white cloudy water and a CYA of 60
    Shocked pool for 3 days at 25 and then maintained at 8, there are no CC's present.
    Current readings:
    Cya - 60
    CL 8
    Ph 7.2
    TA 100
    Calcium 150
    TA 100
    Problem is that the cloudiness has not filtered out in 2 weeks.
    Tried 2 doses of clarifier (cationic polymer), on sunday and again today but only slight improvement
    Any suggestions?
    Mar 2009
    Glendora, California
    Re: Cloudy pool won't clear.
    Are you no longer losing more than 1ppm of fc overnight? If not you are not done shocking.
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
    To expand a little on what dravenone said, either you still have living algae, or the filter isn't working correctly. Doing an overnight FC loss test can tell you if you still have living algae.
