Thread: New Pool under construction ?'s
    Aug 2016
    GULF BREEZE, FL
    9
    At this point not happy PB but no turning back now, day 26, have water and equipment but no electrical. Have been waiting for electical for 10 days.
    Waterline on one end is about 1/2" lower then the other measuring from the cap, pool is only 24' long, is this acceptable?
    Also about 3" of the liner has pulled out in that corner, I would assume due to this difference, will this be an ongoing problem?
    Attached picture of joint on oppisite side by steps, should I be seeing a gap and the top of pool liner?
    Trying to head off and document anything that may lead to continual problems.
    As you can see pool is now a pond, they will be doing initial setup, anything I need to watch out for when the SLAM/Shock the pool. Have been reading that possible equipment damage is not done properly.
    Any input would be appreciated.
    14x28 vinyl sport pool, 11,500 gal, Pentair Easytouch, Pentair SuperFlo VS, Pentair Intellichlor, Pentair CCRP 150, Polaris 380, 1 LED, 2 Deck Jets, TF-100 and speedstir.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: New Pool under construction ?'s
    I'd start following the SLAM process now. I'd dilute my bleach additions in a bucket of pool water since you have no pump. I just posted a thread in the deep end about my experience of no pump for a month.
    I'd make sure to distribute the diluted bleach around the pool peremiter to avoid high chlorine levels right by the liner. I'd also order my test kit today if you don't have one.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Aug 2016
    GULF BREEZE, FL
    9
    Thanks for the info, will take a look at your post.
    Test kit is first on the list, sounds like the speadstir is very useful also.
    Usually on Mondays a person is dreading work, I am dreading dealing with PB and issue's that don't seam correct out of the gate.
    Hopefully someone will have opinion on pool being out of level and long term affects with liner already pulling out.
    triptyx's Avatar
    Apr 2016
    1,438
    The speedstir is a lifesaver - worth every penny.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
