Results 1 to 7 of 7
Thread: Cloudy water
    Aug 2016
    Rockford/MI
    8
    Cloudy water
    So I have completed a week long SLAM as of this morning. Passed OCLT and have no CC. My water started out very green and turbid. Now the color is perfect but cloudiness remains. I can see down to the jets easily, and I can see an object if it's on the shallow floor, but the water is not clear by any means. Do I just keep the filter on 24/7 until the water clears? I did add DE to the filter a couple days ago, and I put some skimmer socks in the baskets yesterday. I am running my robotic cleaner daily as well. Any other tips?
    33,000 gal IG vinyl 20x40 with deep end/diving board. Liner new 2015
    Hayward 300lb sand filter (new 2016)
    Sta-rite pump (unknown model, it's old)
    Taylor K-2006 test kit
    Well water
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,247
    Re: Cloudy water
    Welcome to TFP! Good to have you here
    The SLAM is not complete until the water is clear, so keep your FC up. Yep, filter 24/7. Only other tip is to keep brushing whatever the robot misses daily and seek out any algae hiding places, but you've probably already done that. Don't backwash until filter pressure is 25% above clean pressure. The filter will clean best when it's a bit dirty. Shouldn't be too much longer.
    Good work so far!
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Aug 2016
    Rockford/MI
    8
    Re: Cloudy water
    So even though I didn't lose any chlorine overnight and have no CC there can still be algae? I thought that meant that there wasn't anything living anymore. I thought it was just all dead stuff floating around.
    I did wait to backwash until the pressure went up. Do I have to add more DE then after back washing?
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Re: Cloudy water
    You have met 2 of the 3 requirements for completing a slam.
    1) pass OCLT
    2) less than 0.5 loss on CC
    3) clear water
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    Aug 2014
    Northern IL
    4,615
    Re: Cloudy water
    Backwashing removes the DE so if you want to continue its use you need to replenish it.
    Aug 2016
    Rockford/MI
    8
    Re: Cloudy water
    Got it.
    I rechecked my CYA and it's now 35 instead of 40, which makes sense because we just had a bunch of rain and I had to add some water just prior to the rain. Adjusting my SLAM levels accordingly.
    Working hard to trust the process and have patience. I have a feeling it might be another week before I have crystal clear water. I have noticed a big difference since running the robot every day. I think I wasn't accomplishing much at first because there was some debris at the bottom of the pool.
    Aug 2014
    Northern IL
    4,615
    Re: Cloudy water
    The CYA scale is not linear, so half way between 30 and 40 is not 35, but closer to 38ish. Stick with using 40 CYA for your slam targeting a 16 FC level.
