Results 1 to 7 of 7
Thread: how long pump ahould run
    How long should we leave our pump running? It is left on all the time right now.
    24ft round 4ft deep sand filter vinyl above ground 13500 gallons
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: how long pump ahould run
    Enough to get a complete turn over of pool water. Knowing your size/kind of pump would give you an idea of about how many gpm it pumps. Then just add a some time to make sure.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    All I know is it is a Hayward S-166-T high rate sand filter.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    That's your filter info, your pump info would be listed on your pump...
    The flow rate is 35 GPM.
    DaveNJ's Avatar
    Toms River, NJ
    520
    Your pool volume calculates to 13500 gallons. If you are moving 35gpm in 8hrs it would be 16800 gallons.
    Take a look at How To Determine Pump Runtime in Pool School. You can start with something around 6 to 8 hours as a guess of your turnover time, and then adjust things based on how the water looks.
