Thread: New Newbie First Pool
    Aug 2016
    GULF BREEZE, FL
    9
    Pool is still being built, day 28 and pool is filled, still waiting on electric and deck, with all this time I have had the opportunity to do some inspection.
    It appears the waterline on one end is about 1/2 lower then the other measuring from the cap, is this an acceptable range?
    Also about 3" of the vinyl liner on the low side has come detached from the end wall, concerns?
    Just starting this journey any info would be appreciated!
    14x28 vinyl sport pool, 11,500 gal, Pentair Easytouch, Pentair SuperFlo VS, Pentair Intellichlor, Pentair CCRP 150, Polaris 380, 1 LED, 2 Deck Jets, TF-100 and speedstir.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,267
    Re: New Newbie First Pool
    Welcome to TFP! Good to have you here
    The contractor needs to make good on the detached liner.
    1/2" out of level is more than it should be, but you'd have to look at the tolerance in your contract. It's an aesthetics thing.
    Get a good test kit and in the meantime, add 30 ppm of CYA and 3 ppm of FC to keep the green slime from getting a foothold.
    This kit is the most recommended here: TFTestkits.net
    And you can use PoolMath (button at top of every page) to figure out how much stabilizer (CYA, cyanuric acid) is needed, and the bleach amount as well.
    The first post in this thread is one of best summaries of Trouble Free Pool Care (TFPC): TFPC for Beginners
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
