Thread: another Chlorine high, water getting greener
    Jun 2016
    GREENWICH Ct
    3
    Re: Chlorine high, water getting greener
    I have a similar problem my water was clear blue now it's cloudy and I am seeing a little green on my ladder and on the wall near the ladder do I do the same to clear it up don't have a test kit right know I can take it to get tested at the pool store I have a 18x52 round
    t
    8,200 gallons 18X52 ROUND ABOVE GROUND
    hayward extreme pool filter 100 SQ. FT 1HP Power-Flo Matrix PUMP,
    Design Flow Rate:80 gpm, Maximum Working Pressure:30 gpm, TURNOVER: 8HRS 37,400 GAL.
    Pool store test water right now.
    POOL filled with town water, no water restriction
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: another Chlorine high, water getting greener
    Really need to have some numbers even if there are the doomed and ill fated pool store ones as not having any idea what the CYA is at or what you think high chlorine (FC) is. Just saying it's high doesn't tell us much. We need some numbers, sorry.
    Do you have a test kit on order, TF100 or K2006 ??
    Solar Blanket, Well Water, Borax Added. 68
    Jun 2016
    GREENWICH Ct
    3
    No I don't
    Aug 2014
    Northern IL
    4,615
    Well, we can help you get a perfect pool if you can order one. Otherwise, we're kind of flying blind.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Follow this process as best you can. It is very difficult with no test kit. SLAM
